greasing throw out bearing
Old Jun 12, 2005 | 07:07 PM
94_b18c's Avatar
94_b18c
Default greasing throw out bearing
hi guys another question, i have post before about a squeaky clutch from my car, i already had my clutch adjusted from the pedal coz the squeak seems to stop just enough to take up the play of the pedal thats why my mechanic adjusted it just enough to take out the play, it worked no problem, but i noticed when the car is still not warmed up yet the clutch area squeaks louder than before, the squeak stops after 10-15 minutes when it's all warmed up, you can also hear it while the car is running at lower rpm.so my question is there any way to grease the throw out bearing without dropping the tranny? thanks i advance.
Old Jun 12, 2005 | 07:18 PM
94_b18c's Avatar
94_b18c
by the way clutch is new even the throw out bearing.
Old Jun 13, 2005 | 10:30 AM
Sam92teg's Avatar
Sam92teg
If your throwout bearing is new, then it is factory lubed, pregreased in other words.
Old Jun 13, 2005 | 10:36 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
It isn't possible to regrease it without dropping the tranny and removing it from the mainshaft.
Old Jun 13, 2005 | 08:34 PM
94_b18c's Avatar
94_b18c
my mechanic will try to spray some wd40 through the rubber sleeve that is located on the tranny area i think that's the cylinder, hopefully that one would work, if not he needs to drop the tranny to put grease on the bearing coz clutch and bearing has only been replaced 2 months ago so i thnk it still in warranty.
Old Jun 13, 2005 | 08:57 PM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
You can try to regrease the output shaft of the tranny with a long need like thing. We did that on my old DSM and it helped with the noise some.
Old Jun 13, 2005 | 10:11 PM
Provocateur
On permanent hiatus
You could, but it is usually the bearing itself that squeaks, not the mating surface between the bearing and mainshaft.
Old Jun 14, 2005 | 05:03 AM
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Usually the bearings that come with clutch kits do that, that's why I went back out and got an OEM throw out bearing.
Old Jun 14, 2005 | 08:53 PM
94_b18c's Avatar
94_b18c
well the mechanic already sprayed some wd40 through the cylinder and it didn't work, it is still squeaking, so i got no other choice but to ask him to drop the tranny and grease the bearing or probably replace it, i hope his not gonna get pissed im not gonna pay anything for that it's only been 2 months ago since i rplace the clutch and the t.o. bearing, and it's not my fault.i'll give him a call tomorrow first thing.
Old Jun 14, 2005 | 08:58 PM
Provocateur
On permanent hiatus
He didn't do it right the first time, so he has no right to be pissed off. There should be some sort of warranty and if he can't stand behind his work when something goes wrong, you should find a new mechanic.
While he is at it, you should have him put an OEM throwout bearing in there that he has triple checked for proper lubrication.
