- 1986 Prelude Headlight/Blinker Problem
- IACV problems
- JDM H22 with LSD tranny
- tell me wut u think
- black and tan
- Prelude Headlight
- h22 header fit an f22 block out of an accord?
- I Need A Prelude Help
- timing belt
- 92 Prelude 2.3 si 4ws blew the engine for Christmas, Suggestions?
- Lip Spoilers
- Interior Anyone?
- buying a 2.0SI
- Hey Everyone
- shreeking in first???
- optima battery for prelude?
- is it possible to install 4ws on a 93 prelude si
- does anyone suggest on straight pipe?
- k-teller piping with "mugen" exhuast
- sqweek when startin the car
- Top speed
- Mods for prelude
- crankshaft wobble = bad?
- pulling abs code from 95 prelude?
- 96 prelude si need answer
- Help Me Out
- '89 Prelude 4ws
- Honda Prelude
- Prelude CIA
- Front End Alignment
- Prelude paintwork
- Prelude Si Or Acura Gsr Better
- 92 prelude stero fuse location
- okay here we go
- 5th Gen Transmision Options HELP PLEASE
- 92-96 Honda Prelude Dash Interchange
- 92 4ws....
- d16 in 94 prelude
- Squeaking Noise w/Steering
- JDM Prelude half-mast switch illumination
- clutch noise, oil burn, egr trouble
- Please help!!
- does anyone know how big of a rim i can buy for my honda prelude 93
- does anyone know where to buy a nice turbo
- 1997 prelude oil problem?
- okay heres another question turbo or super charger
- okay i found out how to do it 93 honda prelude s
- Prelude Model Levels?
- 95 4ws?????
- engine light on
- h22 swap-transmission Q
- Gauges
- Stock Spoiler
- 260 wheel horse power all motor
- clock minute counts up constantly...
- shipping a motor
- h23 stroked
- 00 SH oil change
- fuel injectors...
- h23 frankenstine
- Door panel
- Oil Leak
- NationalPreludeMeet.com / NPM06.com now up and running!
- Removing OEM shift knob?
- Shitty cat-backs
- bye bye my prelude....
- Clutch problems Prelude 88 2.0 si
- B20A5/GSR Intake. Need help
- Whats needed in puting a H22 into a SI (h23) body?
- 92 Prelude steering problems
- prelude motor swap
- Stock vs Type S
- port and polished h22a???
- Wierd idling problem
- brake light malfunction yes i have searched...
- brakes actin up????
- type s cams
- Clutch Issue...
- What motor do i have
- prelude rear brakes
- While I was changing my wheels...
- How to (DIY)..plz help
- replacing combo switch
- problem, advice?
- exhaust questions
- Flashing Drive Indicator
- 89 Prelude Si swap info...
- intake???
- prelude alignment problem.
- shift boot question
- H22 crank pulley question
- 4th gen Prelude queries
- Work needed on 93 prelude
- Pelude questions????
- KYB GR-2 Shocks/Struts Set for 92-01 Honda Prelude
- obx stg 2 h22 cams
- block sleeving
- Foglights
- skunk2 intake manifold
- 85' Prelude Engine and Transmission
- plugs fouling out???
- need to find oem throttle body
- 94 prelude help about alt and ps belt(funny story)
- New DC Sports 2.5" Collecter Headers
- Making the H23 Vtec
- how much has it cost you?
- 91 Prelude 2.0si Fuel Pump Question
- v tec controler
- timing help
- Problem with gauges
- Prelude lip
- Need help QUICK!!!
- Gas mileage???
- i need help guys
- Spolier Light Doesnt Work
- New RMF header for my car... so what if it is an Accord?
- Full Pillar gauge pod for 4th Gen... cant find anywhere!
- Clutch won't go into 1st 2nd 4th or Reverse?
- need help...clutch slave cylinder
- 92-96 front bumper question
- ABS light wount go away
- 97 lude??
- Underdrive Pulleys
- ahhhhhhhh
- burning oil badly
- 1989 prelude si
- found my prelude
- affordable intakes?
- speedometer acting up...
- dents
- 99 chipping ;)
- 00 Prelude chipping
- Cloudy Day Lude photoshoot (56k no no)
- Antenna won't go down
- prelude speakers
- Myriad of problems after head install.
- what holds it on.
- p13 4w ecu?
- Alternator going out? Help needed...
- 99 Lude Oil Change
- A Few Prelude Questions
- Take a little Time and Restore an Exhaust.
- 93 and 97 prelude information
- Good deal on prelude?
- 92 Prelude Fog Lights Help?
- ac and ps removal
- Nitrous questions and help please
- Does Any One Need a Clutch for 1998 and Newer Lude
- thinking 2 get cams........any advice
- ??????? help???????? lol
- h22
- O2 sensor write-up
- Considering a 99+ Prelude...
- just got my first Lude...
- H22A Into 4th Gen UKDM Prelude
- Is it just me or do the new Ludes...
- Is the 87 Prelude A Good Car To Buy
- Mugen headlights
- 1st gear shudder please help
- 1991 prelude speed sensor
- 95 lude timing belt Broke!?!?!?
- Vecco turbo kit?
- crap kit
- 4th gen prelude rear bumper "UK"
- 92 Prelude Si Lurch
- body kits for 89 prelude
- Exedy Organic/ACT Streetlite:D
- My Lude
- Jdm H22a 120mph Limit!?!?!
- More than alignment?
- Heat Shield
- Looking for full bodykit for my 00 lude
- iac ????
- Head gasket blew on 90 prelude SI
- Old B20 motors and New Crv motors
- 205/50/VR17 winter tires?
- R1 GTR-7 18 inch rims
- 89 Prelude Electrical Issue(s)
- 84 Prelude 1.6 Carb
- power steering problem
- Help With Oil Leak
- Lowering Ques
- Flywheel install
- h22a vs h23a
- prelude firing order h22
- Jdm H22 Supercharger?
- Fan comes on after shutting car off...
- looking for a new motor to get my prelude running again
- 90-91 prelude si 2.0
- check engine light oon but no flashing light
- h22 igition timing marks
- Thinking about a Prelude...
- Lug nuts
- new wheels
- misfire on all four cylinder
- Brake Spring Compressor For Rear Caliper(Prelude)
- Basslink Sub
- fog lights
- Stock injectors
- Oddometer doesn't work
- rpm question
- TSB for 1996 Prelude Si
- Autimatic Idling
- Right Rod Bearings for H22a
- wierd idling problem when driving
- Fuel pressure
- 93 brake calipher piston wont go in
- Slave Cyclinder Help, '95 Prelude
- s an si
- Flasher Relay!!!!!!!!!!!!!!!!!!!!!!!
- cousins? sort of, same brand
- H23A1 cheapest power gain
- Moonroof conversion pics.....
- new car questions
- speedo doesnt work after new clutch put in
- shuddering
- PRELUDE Distributor CAP
- motor
- JDM headlights
- 1992 Honda Prelude (ALL SHOW)
- Help Me Please
- projector head lights
- cylinder head
- low gears?????
- 4th Gen thoughts
- Ka-Thunk????
- fuel regulator
- ATTS problem?
- 93 prelude lip
- RPM needle goes NUTS!!!
- RPM drop during idle
- Clearcoat problems anyone?
- 98 Factory bodyKit
- Timing Belt
- Yet Another Header Question
- 100 shot on an h22a1
- What would you do?
- New to site Hi from O-town and 92lude :-)
- need some advice
- Prelude wheel specs
- winterizing my car
- dynoed
- any SH owners
- vtec
- air fuel
- manual tranny swap
- exhaust problems
- 96 Lude hesitates/almost stalls out when accelerating, help
- MyPRELUDEdaily
- New 92-96 Black Projector Headlights 4 Sale
