Flashing Drive Indicator
Old Nov 14, 2005 | 02:59 PM
quick_yzf's Avatar
quick_yzf
Default Flashing Drive Indicator
I have a 92 prelude...and a few days ago I try to start it and it won't fire...it starts to turn over but doesn't...I look at the drive4 indicator and it is flashing green while the park indicator is solid red
So after a few minutes it starts....but the d4 light is still flashing and I put it in gear and give it gas but it revs high and barely moves...
I've searched for awhile on the internet and haven't found anything...anyone else have this problem or suggestions on what is wrong with it?
Thanks a lot
Old Nov 14, 2005 | 05:28 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
I think its indicating that there is a problem with the transmission. I belive on the 5th gen auto, it means that the trans is on its way out. I dont know how it relates to your starting problem.
Old Nov 15, 2005 | 12:20 PM
Davey2Crazy's Avatar
Davey2Crazy
Ya I had the same exzact probl;em wit mine. It will do this anytiem the car has been sitting in the sun for a a good amount of time. U need 2 change the Main relay switch under neath the dash. Not 2 costly.
Old Nov 15, 2005 | 01:21 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Yup just got mine changed had the same problem when it was really hot out it wouldnt start, relay is only about 60 bucks
