View Full Version : Prelude
Pages :
3
4
5
6
7
8
9
10]
11
12
13
14
15
16
17
18
19
20
21
- 89 Prelude Clutch Replacement
- buzzing noise
- Coolant lines to throttle body?
- Oil Consumption
- Looking to buy a 2000 Prelude, have some questions.
- Quick Tire Question
- Brake Booster Question?????h22a1-h22a4
- Engine Stall Problem? Help!!!!
- h22 swap knock sound
- B20A conversion H22A
- New 01 Lude owner, Concern about ECU/Rev Limiter
- Need a place to build my H22A4
- Cant get lude in gear!!!!.. Please help
- Type SH ... shocks ???
- Many Problems: Guru's Needed
- Many Obstacles: Guru's Needed
- b20a "88" Prelude
- Larger wheels and tires and ATTS
- Need Creative Ideas
- K&N Typhoon
- Prelude vs Integra
- stupid question
- Prelude Advice
- NEED HELP 99 prelude ecu diagram
- sorta new headlights!!!!
- new clutch....
- 3rd gen shaking while idle
- Need A Brief Lesson
- need help with parts
- Prelude BB4 headlights on ebay
- 5th gen lude stuff
- wanted 5th gen lude steering rack
- 2nd gen talon turbo on prelude
- New Jersey Car Owners!!!! Please Help.
- Problems with H22 and ECU
- Weird Engine Noise ... Video Inside.
- HELp..
- iPod
- FOR SALE - Neuspeed Sport Springs 97-01 Non SH- Under 1,000 miles
- Difference between Base and SH cluster
- engine swap
- 2000 Prelude 5spd vs 2004 TSX 6spd??
- HID questions
- Got my Prelude!!!
- 97-01 Honda Prelude True Short Shifters now shipping
- Finding Spring Rates
- Silver 4th Gen ludes in here.
- Prelude Chip??
- New 2 boards...
- need help with my 5th gen!!
- 85 'lude alt install problems HELP!
- This noise scares me !`
- 88 Lude electrical probs.
- Stolen Prelude!!
- can a 5G supercharger fit into a 4G
- RPS Clutches??
- Gen 3 Radio Question
- Engine Hesitation and Vtech Not Kicking In
- '88 heater never warms up
- Bright Bulbs
- Non POP UP Headlights
- Prelude base vs. Prelude Type SH
- A/C Problem???
- Throttle Body Sensor
- shrinking gas tank?
- What Should I Do???
- Essenza Type R Tires????
- 18" wheels
- Squeek
- '89 Prelude seatbelts
- Alternate trannies for '89 Prelude Si?
- Help!!! Drivers side mirror replacement
- how to remove cente console where AC controlls are
- prelude vs prelude sh??????
- Tensioner/timing Belt
- header question
- Winter Advice
- 92 Prelude Jdm
- Tires
- Idling problem
- Adjusting Ur Valves
- ATTS check light?
- Anyone know?
- h22 info
- Are these taillights legal?
- Clutch problems, weak pedal???
- Vibration
- Red calipers on a Green Lude
- Bad oil leak
- Matching Paint????
- H22A4 Engine rebuild kit?
- mazda3 vs lude
- Which 5th Gen Body Kit???
- question about camber kit
- lambo doors
- Wheel size, offset, etc..
- buying 93 prelude, what to look for
- Where do I find the MIL bulb connector?
- 97-01 prelude oem body kit?
- Prelude Bolt Pattern
- balancer shaft questions?
- Best tires for 18's on a 5th gen
- what is the different in 97-01 base ecu vs sh ecu
- Turbo Setup
- Not sure what they're called...
- h22 auto timing tensioner
- im really scared please help!!!
- Wheel offset..please explain!!!
- Question about Mileage
- Just a question
- weird engine noises!!!!
- S2000 rims fit Prelude?
- Heel toe
- 440 hp 99 prelude sh turbo
- Possibly buying brothers Prelude, is his price fair?
- Please clutch help!!!
- P1259 & P 1456 Help please...
- Wings West
- Computer Codes
- need help quick
- Cheap Mugen Headers!!!
- Weird tapping noise just over idle.
- bad gas mileage!!!!
- 97 Prelude with 4WS
- How much ur tints cost??
- Gas Mileage
- Ok 1992 Prelude Mechanics, please help!!
- Paint Estimate
- planning on swapping a 88 prelude??
- Skunk2?
- 2 questions :
- 98 Lude SH DTC P1259
- Carfax Please ? Thnx n advance
- Rev Hard Kit
- Can you fix an ECT sensor plug???Anyone have one?
- 93 Prelude H23 to H22a swap
- 5th Gen. Short Shifter?
- f22 swap questions
- how to turn check engin light off?
- about to buy 92-96prelude are there any surprises like rotor hard to get off
- H23 Lude ---> H22 Swap
- Bearing Noise when accelerating
- crank scrapers?
- Modifications need to fit a Supercharger in the 4th Gen
- reset ecu??
- USDM vs JDM h22 a/c lines
- Prelude Owners: Help!!!
- Parting out a 98 Prelude SH..Chicago
- UNDERDRIVE QUESTION on 3rdGen Prelude
- AEM Pulley Installation
- Personalized License Plates
- A thought??
- Odd problem with HID Kit 4th Gen
- bought a lude last night--need front end help
- 95 h22a problems HELP!
- Timing Belt Cheat Code
- Trunk cluster light probem please HELP
- Help!!!!!!!!!!!
- Location of ECU
- air flow converter?
- adjusting projector headlights
- need help with headlight...
- Is this hydrolic or cable tranny?
- Will a supercharger fit in a 94vtec
- 98 Lude Blue LED Conversion
- Tires
- Rear View Mirror...Please Help
- Problem with swap.....!!??!H22a
- Reset 4WS
- Removing clock/ac vents on 5th gen prelude
- shocks leaking
- Carbon Fiber Hood and Trunk
- replacing head gasket
- Question on Warming up my Prelude....Vtec doesn't kick in.....
- Help need for rebuild
- How do you pull the codes from the ECU???
- n00b Prelude Type Guy
- Replacing Ball Joints on 4th Gen
- help with drive shafts
- Cost of adding a spoiler to a 5th gen?
- high idle and up shifting at WOT
- need firing order
- Paint Bubbling
- Supercharging Quesions
- lost pressure in my clutch
- throttle body size
- ES Trailing arm bushing replacment....
- Anyone have a Jackson Racing Supercharger on their lude???
- where to go for 60k service for 98lude SH
- Eyelids for 5th Gen
- Cold Air vs. Cold Air V2
- Can you boost 10psi on stock internals (h22)
- someone help i need helms 1 page!
- motor swap, need input please
- Need help with a H22a swap into a 95 prelude with H23
- h22 sleeves
- ABS brake light on???
- Prelude 1/4 Times
- 95 VTEC Prelude vs. 94 Integra GSR -- shopping
- Okay, tell me I didn't just get TOTALLY ripped off....
- GTI VS Prelude Vtec
- Gran Turismo4 - Preludes On! Pics Inside!
- Anyone with '89-'91 Prelude 2.0SI (b20a5)
- what will be easy and cheap to swap?
- Radio
- Trunk water leak in 4th gens??
- harness help
- Please Help
- question about cams
- Oil Pans: Stamped vs. Cast.....
- h22a1 swap
- Nut size on Cat converter
- Check out my '89 lude Si
- Door locks?
- Telll me about the '91 Prelude S
- 89 Prelude Questions
- does my stock 89' Prelude SI have vtec?
- Recommendations on CAMS and Pistons
- JDM sidemarker installation...
- Crank Pulley
- fuse keeps blowing?
- 1985 prelude 1.8 dc parts car
- H23a From A 94 Prelude With 4ws
- Tranny - Good days and bad days
- code p0133?? please help
- 5th gen door handle stuck out? Help
- for all those who swapped out their h23's
- Need some advise on the rear camber of my car....
- 90 Prelude Radiator-Help
- hey just checking in also a Q about slotted rotors
- Hydrolock
- Help!! Stripped oil pan drain bolt!!!
- tire size question
- JDM H22a Injectors? where can i get them
- 4th gen wont start please help!
- What constitutes Rice?
- Gimp mode?! Lil or no Vtec?! lowered Revlimit?! HELP
- Lude tire recommendations
- Opinions plz
- H22a vs f20b
- those with Si 5-speeds
- Uhm ok.. H23 - H22 swap
- How do tell the difference????
- Whats The Best Tranny for a Lude!!!!(HeLP!)
- 89 Prelude coupe and 89 Integra questions
- 95 Prelude CAI Insturctions
- fuel managment system
- Broken Speedometer
- Prelude Type SH??? ATTS
- question about my cat
