ABS brake light on???
i dont know what to do. my fluid is up but for some reason a little yellow abs light is still on. also sometimes my ebrake light comes on even when it is not engaged. what should i do and what is wrong??
Assuming you are not seeing a check engine light I suggest you run the ALB diag.. Which is done by jumping the little blue connector behind the radio and counting the flashes from the ABS light. I know I'm currently getting a 1-2 which means I got a bad ABS pump (ugh.. expensive)
More info
click here
EB
More info
click here
EB
Thats Crazy, I just bought a 2000 Lude the other week and I have been having the same problem. Ive had the ABS system looked at at the dealership but they said nothing was wrong. It turns on at random times and so does the e brake indicator. Anyone have any ideas
