h22 swap knock sound
Old Jan 4, 2005 | 01:19 PM
smooth95's Avatar
smooth95
Default h22 swap knock sound
sorry I posted this in the wrong place earlierI just got my h22 swap in my 95 accord and I just started hearing a knocking sound after I change gears or when I let the throttle go then I punch on the gas and then I hear it but it only knocks once not countinuesly Im thinking something must not be tightened right has. anybody had this problem?
Old Jan 4, 2005 | 07:01 PM
JdmDC5's Avatar
JdmDC5
Rod knock?
Old Jan 12, 2005 | 03:57 AM
dalcam's Avatar
dalcam
Default Poor Bastard
My old B20A6 did exactly the same thing, it threw a rod...Number 3...Does it knock slightly 4 a second when starting first thing in the morning (dry start 4 a second) & does it starty knocking when the oil hits temp, noticably above 3000rpm...It would also knock under load, above or rather much worse above 3000 rpm...
Old Jan 12, 2005 | 02:52 PM
ludeboom's Avatar
ludeboom
yea u need to be A LOT more specific on this one, many people dont realize that the h22a is just a noisy motor, standing next to my car right after i adjusted my valves to spec sounds like a sewing machine. The injectors and valves make A LOT of noise on the h22a. Every time i work on my car i always get worried at first because it ticks, until i rev it to 8000 with no problems, then i feel better because its done this for the 91,000 miles since i rebuilt it.
Maybe get a recording of this noise? That would be the best bet.
Dalcam, the b20a6 is an ancient motor, and has nothing in common with the h22a. If he had rod knock he'd most likely be blowing smoke at idle and one trip to 8000 would finish off the motor.
~kris
