View Full Version : Prelude
- Lowering seat in prelude
- Fogs: Clear or Yellow
- JDM Headlights with yellowing..
- Prelude Websites
- Making a motor fit?
- Thermal R&D Exhaust
- can't find Oil Filter
- short ram install
- h22 swap tranny hosses ???
- 1990 2.0Si parts needed
- New here
- prelude from heaven...new pics...56k murder
- 85 prelude cv boots
- Oil Filter Noise
- help need to be enlightned
- 92 prelude crankshaft bolt. please help
- Can someone please carfax this VIN for me?
- wtb oil pan
- Jdm Cc???
- 4th gen head lights
- thinkin of gettin a 4th gen lude
- power steering leak
- backlogging ECU.
- clutch problems I think?
- gass prices
- Newbie questions about an H23A1
- Just crusing
- JDM f22 ecu
- Which corner lens?
- cel after rack replacement???
- Prelude 5th Trunk Lid
- Defeating the Immobilizer
- STR 570 Pro cam gears
- wheels tires size?
- need jdm f22 dohc ecu?
- engine light manually getting code?
- brake lamp
- turbo and ac
- question on h22 turbo
- Timming belt issues HELP
- Please Help! No Radio!
- 4th gen rear rack question
- Lude coolant problems
- 89 Prelude Misfires
- 97-01 Prelude Headlight bulb
- Inspection..
- Mugen front bumper
- 5th Gen Shop Manual by Honda
- rack & pinion leaking?
- 97-up prelude Wing West add on kit (new)
- 92-96 h23 knocksensor location
- cam adjustment
- What else to do with my check engine light?
- crank pully help!
- Headlights and taillights
- Wheel Spacers
- burning too rich
- advice on buying (newb)
- Help check engine light always comes on.
- Details on swapping a H22 into a Prelude SI model?
- 98 SuperCharge, or TurboCharge
- Greddy turbo kit 92-95 civic ex
- A/C climate control lights
- H22 what should I do?
- 1992 prelude s HELP!!!!
- PS2 Slim in glovebox
- need help please
- timming
- Quick Question!!!
- 4th Gen Prelude TSBs
- h22 vtec or h23 vtec which is better?
- How to Install.....Buddy Club Earthing Ground Kit???
- 89 Prelude SI - What's wrong now!!!!!
- Prelude front pads
- Wings West RS Installation??
- Looking for spare body parts
- screaching
- What is it...?
- took motor out my 93 perlude
- Do It Yourself Honda Mods!
- Problem with Turn Signals
- 93 honda prelude h22 worked for sale
- Power Problems???
- brake master cylinder
- 91 prelude won't go into gear
- Stock P72 ECU on Skunk 2 manifold
- HELP ME ! Plz *Wiring prob*
- So let me get this straight, OBD2 question
- 175,000 miles
- Dyno vid, Golden Eagle sleeve forged internal type sh
- Nice 'Lude
- Q Logic Sub Box
- Acura Cl 3.0 1997 Aceleration 0/60
- gauge cluster help
- prelude lsd?
- Bumper install
- 92 Prelude S
- what motor?
- What bumper is this?
- Honda In-dash CD Changer
- Clutch Master Cylinder - Advice Please !
- timing!?
- 1995 Honda Prelude VTEC A/C Blowing Hot AND Cold air
- 1990 and 1991 Prelude Si 2.05
- Question from would-be owner
- year of motor??
- NiCE setup
- clock fuse? Help!
- H22a4?
- air-conditioner
- s or si? I can't tell
- how do i get my front bumper off?
- what is an sh?
- Dumping the clutch
- Next Thing To Buy!!
- Power Window/Mirror problems! HELP!
- PLEASE READ.....Just got car back......They Painted my Valve Cover?????
- Im a NOob **pics**
- HLP anit-lock brakes is removal possible?
- will i fit?
- Question about Vtec
- Help me find this part.
- H22a distributor problems
- sport shifting vtec
- Dont Buy those JDM spark plug wires on ebay
- transmission?
- installing deck to prelude...
- where is the TDC Sensor on a f22a1 motor? top dead centre sensor??
- 5th gen prelude check engine light pulling error code 18
- Engine Problems
- help me on my 98 SH
- just bought a 98 prelude [need help]
- Distinguishing preludes
- Tire Tube???
- ??? About HP
- Check Engine light on just installed new motor on prelude
- Need help 5 speed trans problem
- tire rubbing front fender?
- h23 frankinstien
- cam seal leak
- engine swap
- is the 92 SR considered H23? (new to honda)
- ABS troubles
- 1992 prelude. Looking for some ideas???
- ECU...What should i do?
- 95 prelude si
- Problem with 99 SH Overdrive
- 89 Prelude-NOtaillights-cop pulled me for Brakes!
- 98 type sh shocks
- Why won't the car start?
- Need Some Advice
- 89 prelude turns over won't start or fire:
- H22 swap into 92 prelude...
- h2.3 block + h2.2 vtec head = Help me please
- How much would you pay...?
- e-brake boot
- dc sports headers
- I recently swapped my h22 into my f22 prelude got a question about vacuum hoses
- 4ws code 72, i wanna get rid of it. pls help!!
- Golden Eagle sleeved 5th gen
- oil pan drain plug
- 95 Prelude SI - How to remove door panel?
- Greddy Header for H22
- 97 prelude...Power door locks not working
- power door lock and keyless entry
- Tornado??
- Thanks, TXDOT
- problems with ecu
- 88 prelude ac question - red light
- Help Please - leaks and creaks!
- Farewell Prelude...
- help with changing fuel filter please
- 2001 Prelude S Upper Control Arm Question! HELP!
- Wing West Lip Kit Installation
- Body Kits
- Camber Kit Install on 2001 Prelude S
- Glowing Side markers
- Engine Will Not Start!!
- Shocks
- h22a build
- Prelude Transmission and maybe swap
- 97 - 01 Prelude Engine Valve Cover!!!!!!!!!!!!
- 95k mile tune up tips
- symptoms = clutch?? clutch master/slave cylinder??
- Oil leak from oil filter
- radio
- thinkin about buyin a prelude...
- How to manually open hood on 95 Prelude?
- Hey guys, need a hand, maybe you can help
- cd payer hook u p
- wiring diagram for radio
- Holley fpr
- High Idle
- Headlights not going down
- brakes
- spark plugs
- Honda Predude Factory OEM Car Cover 88 89 90 91
- Prelude Security
- Looking for pillar pod
- Question on Honda Dealership advice
- Stalling 5th gens look!
- Anybody use this stuff?
- H22 swap in Civic 97
- how do i clean throttle body
- Kinda curiuos:How can you tell if a motor is blown?
- aem cold air v2 intake
- vtec
- 92/94 h22a dies sometimes, need to fix SOON
- JDM in UK headlight thoughts...
- 1992 Prelude transmission fluid reservoir
- prelude question HELP folks
- wtb a prelude
- Thinking of getting a prelude, please help!!
- Need Help Asap
- headlight conversion
- Wing West Lip Kit Quoted
- Used Engine Reliabilty?
- prelude antenna again
- please help!!! THINKING OF SELLING MY SH
- H22 Longblock with H23 parts?
- 89 prelude no star, no crank, no sound
- looking to get a lude
- vtec problems
- broken driver's side door, help!!
- Loss of power in my 99 SH, help!
- i have a sponser
- H23
- Paintjob decision help
- 91 Lude B21 Rebuild
- rpm problems
- Paint Job
- Handbrake
- h23a1 diagram of motor
- iidle problem
- can i remove the ABS 91 prelude
- JDM headlight problems
- i have a question for F22 owners
- ??? Prelude with Air Suspension (Lowrider). ???
- 4th gen ignition questoin
- '92 Prelude 2.3i won't start when engine hot
- Lets make my cousins Lude fast!
- recommended alarm system for a '95 SE
- All black 5th Gen pic request.
- catalytic convertor for a 95' prelude SE (california compliant)
- 4th gen prelude question...
- Need help with my Transmission problem
- fitv help please!@!!!
- Fuel?
- compression test
- i found a h22a4
