Need help 5 speed trans problem
Old Jul 29, 2005 | 03:21 PM
toddrgudde's Avatar
toddrgudde
1995PreludeSI2.3
Default Need help 5 speed trans problem
well here it goes i am new here so hi to everybody i have just got a prelude through my father in law who buys and sells cars. it is prelude si 2.3 5speed i am tring to deteman if the trans is to blame or if its the clutch .Ok no matter which gear you are in you have to put a lot of force in to it some tome it like th clutch isnt even pressed if you fluter the clutch somtime it will go in when the car is off it is as easy. the slave cylnder has ben blead seems to be working good any one have this problem or have any ideas on what it could be thanks todd i am a professiona alarm and audio instaler if any one needs help
Old Jul 30, 2005 | 06:11 AM
prelude1897's Avatar
prelude1897
Have you checked your master cyclinder? Might need to replace that, and while you're doing that, replace the slave cyclinder
Old Aug 8, 2005 | 08:23 AM
Ludemandan's Avatar
Ludemandan
Prelude tracktion
Poke your head down under the dash and look at the firewall under the clutch pedal. There is a piston that presses through the firewall. If there's clutch fluid leaking and your firewall is wet, the master cylinder is leaking.
Dan
