97 prelude...Power door locks not working
Old Jul 20, 2005 | 09:19 AM
01blackerado's Avatar
01blackerado
True Techy
Default 97 prelude...Power door locks not working
Whats up fellas, I need some help with my girls prelude. We took the car in to a buddy of mine to get it painted, now when you hit the door lock switch...it wont do anything. We checked all the connections ( from behind the door panel) and the switch was connected in the right spot. It even sounds like the relay is working cause when you push the switch it you can hear a clicking noise down behind the dash somewhere. What could it be...bad accuator or something??? Thanks for your help in advance
Nick
Old Jul 20, 2005 | 10:21 AM
foot's Avatar
foot
Take it back to where you got it painted and tell them your story.
Old Jul 21, 2005 | 04:28 AM
01blackerado
True Techy
Trust me, thats the first thing I did he cant figure it out either
Old Jul 21, 2005 | 08:14 PM
foot's Avatar
foot
It's electronic. Troubleshoot it. Check for power and ground. If you hear the relay click, good. Check for power at the actuator. Check for power at the switch. You can check the actuator by supplying it with 12 volts and a ground. The only way to know is to start checking the circuit.
Old Jul 22, 2005 | 06:40 AM
01blackerado
True Techy
Do you happen to know where the relays are located?? Behind the dash or under it or in the engine bay
Old Jul 22, 2005 | 09:31 AM
katana62678's Avatar
katana62678
Dashboard
File Type: jpg
Old Jul 22, 2005 | 10:06 AM
01blackerado
True Techy
Aaaahh thanks dude, you helped me out big time
