oil pan drain plug
Old Jul 20, 2005 | 02:02 PM
loose cannon's Avatar
loose cannon
Default oil pan drain plug
i have a small leak from my drain plug and i know that the drain plug is slightly stripped. I was wondering if anyone has tried putting in a larger sized drain plug or the supposed selftapping plugs. the only other option is to change the oil pan which i don't really want to do b/c the pan alone is like $210.00 anyone with experiance with this please let me know any info you might have.
thanks
Old Jul 20, 2005 | 02:44 PM
VPUPPY's Avatar
VPUPPY
has the drain plug crush washer been replaced every oil change?
Old Jul 20, 2005 | 02:46 PM
loose cannon
i think so i usually have the dealer change the oil
Old Jul 20, 2005 | 07:04 PM
foot's Avatar
foot
The torque is about 30 ftlbs on that bolt. Someone overtightened it at one time or more. Replace the pan and stop taking it to jiffy lube.
