Oil Consumption
Greetings!
I am newby to this forum (but not to Preludes), so I apologize if I am posting something that has already been beaten to death.
What is the experience of all you 'Lude owners with oil comsumption? My "98 has always eaten a quart or two between oil changes. Am I alone?
:beer:
:beer:
Its from being at high RPM, everything spinning in the head (mainely the cams) creates high oil pressure in the head. To relieve this pressure there is a hose going from the valve cover into your intake piping and the oil goes into the intake manifold which gets burned. Going through oil when you VTEC is only healthy.
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
The 5th gens generally will smoke a little in VTEC, but not when driving normal or at idle. If you do see smoke when you're not in VTEC, there's a problem.
So long as you change the oil regularly and keep the level up (I check mine every time I fill up the gas), you should have no problems. These are pretty bullet proof engines if maintained properly.
A Philanthropical Fruit
Originally Posted by Jefelude
Thanks for clearing up the mystery for me. I love the VTEC song, so I like to make my 'lude sing when the situation allows.
A little chin music
If you are in VTEC frequently, check your oil every time you put gas in the car. Get into that habit. I always keep a quart of oil in the trunk so I can just add a little when I need it. I know some people think I'm either insane for buying a car that normally burns oil or my engine is bad.......
I tell them it's a Honda thing. They wouldn't know
