question about camber kit
Old Dec 7, 2004 | 01:10 PM
sharkwing1's Avatar
sharkwing1
Default question about camber kit
I bought a 2000 prelude with 17" enkel wheels and the previous owner installed a camber kit. Now I want to go back to stock. Can i just bolt on the stock wheels or does the camber kit need to come off? I dont really know anything about a camber kit thanks
Old Dec 7, 2004 | 03:13 PM
5hift's Avatar
5hift
Hades: 2.2L DOHC VTEC
Is the car lowered at all? That'd be the only reason you'd have a camber kit, If it isn't lowered then there's no need for it. Either was, if you're gonna leave the suspension the same and just switch out wheels, you shouldn't have a problem.
Old Dec 7, 2004 | 05:50 PM
sharkwing1's Avatar
sharkwing1
so Worse case scenerio, the car would be a little lower? thanks
Old Dec 7, 2004 | 06:29 PM
5hift's Avatar
5hift
The car wouldn't be any lower because of a camber kit. There really is no worse case scenario there. You're all set when u want to lower your car and it won't affect anything with stock suspension either.
