need help...clutch slave cylinder
Old Nov 3, 2005 | 03:06 PM
hondarider98's Avatar
hondarider98
Default need help...clutch slave cylinder
Hey guys i need a little help here. I recently changed my clutch master cylinder and now a couple of weeks later my clutch slave cylinder is now leaking. I spent a long time on the net looking on how to DIY but cant find anything. So does anyone know how to change the clutch slave cylinder in a 98 prelude? If so could you post it of pm me.
Old Nov 3, 2005 | 03:35 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Here you go.
http://www.superhonda.com/forum/show...&threadid=5073
Basically just remove and replace, make sure the input line is in tight and bleed.
Old Nov 4, 2005 | 01:03 PM
hondarider98
thanks...i try it out this weekend. Does anyone else have any other links
Old Nov 4, 2005 | 03:00 PM
hondarider98
does anyone know if you have to take the fan out to do this...the last 2 bolts are quite a hard one to get to. And if anyone has done this could they let me know what tools you needed...i have a full socket set but was wondering if you need any wrenches.
Old Nov 4, 2005 | 03:38 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
I didint. But it was kind of hard to take it out.
Old Nov 5, 2005 | 10:51 AM
prelude1897's Avatar
prelude1897
I didn't have to take fan out. Just use a small socket wrech to take the bolts out.
Old Nov 5, 2005 | 12:02 PM
hondarider98
is this a hard job...is there anything else I should know. Or is it just a straight bolt on and bleed job. Somebody was saying about leaving some slack for the pump to work. I just dont feel like paying over $100 in labour to fix this.
Old Nov 5, 2005 | 08:07 PM
prelude1897
Its pretty easy to do. The only hard part is putting the bolts back in, but once you get one in, you should beable to get the second in
Old Nov 5, 2005 | 11:39 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Thats it. Ive heavent heard of this "leaving slack for the pump to work".
Old Dec 8, 2005 | 01:26 PM
jhimed's Avatar
jhimed
Default Hydralic Clutch system location
thanks...i try it out this weekend. Does anyone else :
Here is a link of the breakdown of the hydralic system for the clutch.
http://www.hondaautomotiveparts.com/...ASTER+CYLINDER
