Wierd idling problem
Old Nov 18, 2005 | 10:05 AM
preludedriva's Avatar
preludedriva
Default Wierd idling problem
Ok i got the jdm h22a in finally but i got this wierd idleling problem when im just sitting there idle/at a stop/etc
it will rev up from 1000-1800 rpms
BUT it only does this when my headlights or my heater is on
the shop i took it to get the work done says its a short in the harness
some people say its my o2 sensor some say its my iavc some say this and that
ive turned the iavc screw (the one on the TB) all the way to the right and it still hasnt stopped the problem
there are no vacuum leaks (that i know of ) that i know
was wondering if any of you had any idea how i can fix this
Old Nov 18, 2005 | 11:46 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Default Idle
Thats the Throttle Screw not the IACV, The IACV is located under your Intake Manifold, this connects to your FAST IDLE VALVE, I had the same problem you need to take off the IACV and turn the bullet on the inside down a couple of turns, also check if there is any air in your coolant, you may want to bleed out the coolant a little bit to make sure there is no air,
Also is the check engine light on, if so run the codes and let me know.
Old Nov 18, 2005 | 04:11 PM
preludedriva
ill try that thanks
