fuel injectors...
Old Nov 30, 2005 | 06:19 AM
edulerp87's Avatar
edulerp87
Smokin Lude
From: wappingers falls ny home of the gangsta rednecks
Default fuel injectors...
ok i got a full exhaust and headers on the way....just wanna know what should be my next step..i got my intake and ill have my exhaust...im thinkin we could use some more fuel...so my next purchase will be :
fuel rail
injectors(what size should i go with..i do plan on doin some major work turbo+ect.)
fuel pump
regulator
what else will i need and whats the best kind of stuff to get thanks alot garrett
Old Nov 30, 2005 | 09:22 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
None of that stuff is needed with just intake and exhaust. I would get some suspension gear instead, starting with springs and struts or maybe some good tires. Just my opinion.
Old Nov 30, 2005 | 12:34 PM
shivers's Avatar
shivers
Moderator Alumni
You're nowhere near needing more fuel. If you're planning on getting a turbo, you should have held off on the header since you won't be able to use it. In the mean time, you could think about picking up a VAFC and getting the car tuned. You won't make a huge amount of power, but it will definitely smooth out your power curve and get your a/f ratio in line.
2005 s2000
