prelude alignment problem.
Old Nov 13, 2005 | 09:55 PM
hidewai's Avatar
hidewai
Default prelude alignment problem.
1996 prelude si the car pull to the right side.had 2 alignment done it is fine. alignment is perfect.but car still pull.not going straight.4 tire 205-55-15-are brand new.any one has this situation.bridgestone tire expensive one.also test drive several 93-96prelude same problem i think is very common.need quick answer prelude owners
Old Nov 13, 2005 | 10:12 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Ok, Thanks for contributing.
Old Nov 13, 2005 | 10:16 PM
hidewai's Avatar
hidewai
1996 model
Old Nov 13, 2005 | 10:22 PM
Mkazm83's Avatar
Mkazm83
Snapping bolts
Originally Posted by hidewai
1996 model
Pictures?
Old Nov 13, 2005 | 10:23 PM
Samson's Avatar
Samson
chris is the devil
1996 model
would that be an S, Si, or VTEC model? this info is very very critical. you must be certain.
Old Nov 17, 2005 | 08:54 AM
Altern8r's Avatar
Altern8r
hidewai you live on the american continent so you allignment must pull to the right so if you fall asleep it will go off the road and not into on coming traffic. as here in ireland ours pull to the left. OK.
Old Nov 17, 2005 | 10:23 AM
FooD2000's Avatar
FooD2000
Still Water
are you lowered at all? also are your tires some cheap ones?
i'm in the same boat, you might be getting radial pull from the tires.
