89 Prelude Si swap info...
Old Nov 14, 2005 | 09:22 AM
TEGG2's Avatar
TEGG2
Looking for a Teg!
Default 89 Prelude Si swap info...
...i need some swap info for a friend...tried the search all it brought up was civic info...anyways my friend is buying an 89 Si w/the b20...the heads are warped and he needs some help. he's looking at a couple different options right now: swap the h22a, swap a b18c1 or c5, or new heads...on the h22a swap what exactly is needed? on the b18 swap what exactly is needed? and on changing out the heads i've heard that you can make a frankenstien engine by putting the b18 or h22a head on the b20 block...is this true? if it is would putting together an engine be easier and cheaper than getting the whole engine? thanks for any help/info you can give...
Old Nov 14, 2005 | 10:56 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Default Wow
You are lookin at alot of work and thousands of dollars, I would replace the B20, get it running nice and sell it, then buy a newer gen.
Old Nov 14, 2005 | 11:16 AM
TEGG2's Avatar
TEGG2
Looking for a Teg!
yah we know but the thing is the car is only going to cost 500$, the body is straight, the transmission is rebuilt, all the power accessories work and have been replaced...after the guy did all that he bent the valves and warped the head after he tried to replace the head gasket and didn't notice he ripped it, and the timing belt shredded....so basically the bottom end is good but the top end is gone...that and i own an 89 celica so we want to keep it old school and show up all the guys who think their new cars are badass...so that is why we are just looking for information because honda's are a new field and we're trying to do research to do this right.
Old Nov 15, 2005 | 11:24 AM
F22B Prelude
Rachel Bilson
Aight, Well I haven't heard of a B20 bottom and a H22 Head, for a 3rd gen I have seen and H23 bottom and a H22 Head, that swap is straight up, I havent heard of swapping the whole H22 engine into a 3rd gen. but anythings possible, from my knowledge this is what you will need.
1.) New Tranny, either H23 or H22
2.) New Engine, either H23 or H22, either whole H22 or H23 bottom-H22 Head(good luck on finding an H23 in the first place)
3.) New CV joints
4.) Appropriate ECU and wiring harness
5.) Then weld and cut to get all that shit to fit in a 3rd gen.
Don't know anything about B18 you might want to try the Civic or Integra forums.
Good Luck
Old Nov 22, 2005 | 04:35 PM
preludeintroubl's Avatar
preludeintroubl
i have a head for a b20 if you want it, i dont need it i bout the 2nd prelude for the trans and all the rest of the parts are up for grabs, the car i bout is a si model
Old Nov 22, 2005 | 08:40 PM
Phateless's Avatar
Phateless
S2K compatible
b20 block with h22 head is not really viable. you can do a CR-VTEC, which is a b20 block with a b16 or b18c head. frankenstein motors like that are not smog legal in cali tho. i looked into this a while back. there's some good info on honda-tech. basically it's a pain in the ass. the b20 in the 3rd gen leans back a bit, which makes fitment of other engines very complicated. i don't think a gsr motor will clear the hood either. i would imagine a b16 or b18c swap or a frankenstein motor would be your best bet.
keep in mind, i'm just relaying what information i've picked up so far, so i may have some (or all) of this stuff wrong. be sure to double check everything before you pull the trigger on this.
props for trying, i think a 3rd gen vtec lude would be awesome! those cars handle like a dream, and with a gsr motor in there, they'd fly!
Old Nov 22, 2005 | 08:51 PM
Phateless's Avatar
Phateless
S2K compatible
not encouraging...
http://honda-tech.com/zerothread?id=1290226
looks like you're better off putting a CR-V b20 block with a gsr head into the prelude. the prelude block looks like a nightmare to vtec.
http://honda-tech.com/zerothread?id=410899
i know there's info about putting a complete gsr into the 3rd gen lude, i found it before. i'll see if i can track it down for you.
Old Nov 22, 2005 | 08:53 PM
Phateless's Avatar
Phateless
S2K compatible
https://www.honda-acura.net/forums/s...ad.php?t=76627
Old Nov 22, 2005 | 09:50 PM
Phateless's Avatar
Phateless
S2K compatible
bingo!!!
http://www.teaminterlude.com/3rdGenH22Swap.asp
Old Nov 23, 2005 | 10:45 AM
89ludaTUNER's Avatar
89ludaTUNER
89ludaTUNER
Droppin the H22 in it would probably be the best bet, it's a more common swap, and the parts needed for it are readily available. But it's gonna be a tight fit. tell your fiend to open up a lil room, and gain some extra power, consider losing the A/C. check out enjo for the mounts.
For the frankenstein hybrid, I'm not 100% sure, but I believe you have to swap the head bolts around, requires some machine work.
If you decide to just beef up the B20, make sure you get a reliable head gasket, B20's are notorious for blowing them.
and a lil personal preference, use redline oils, they're proven to free up some free power.
You should check out reace engineering's site, really halpful people <<<raceeng.com>>> tell em BIBO sent ya.
