View Full Version : Engine Swaps, Tech & Tuning
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
  1. Honda VSA Question
  2. please help
  3. advice on my set up
  4. How much whp?
  5. Dont Buy FRom StreetImports.com
  6. Need help 89 EF DX Tricky Problem?
  7. Hi Car2n & his LegeNd-SX is here!
  8. ls vtec HELP
  9. D16y8 intake manifold with B18b throttle body = 12 hp?
  10. making a B18C5 california BAR legal
  11. 97 ITR Problems after high compression installs
  12. Wastegate springs?
  13. Help please.
  14. k20a2 kpro mapping
  15. K20A2 kpro map
  16. Turbine wheel to housing issue!
  17. replaced head, 0 compression all cylinders
  18. EP3 k20a mapping
  19. 96 Acura TL
  20. Ignition Help with H22a
  21. 1999 Honda Civic LX Horspower
  22. B18C SWAP 92-95 coupe HELP NEEDED!
  23. H22 swap q
  24. gsr fully built.
  25. honda civic engine swap ( wont rev)
  26. please help someone!!! g1 integra gsr swap. help!
  27. honda civic engine swap
  28. acura EL wont shift gear
  29. g1 integra gsr swap. help!
  30. Swap question for a 97 Civic
  31. B16a Went Bye-Bye
  32. Which Header would make more/better pwr on a stock H23A VTEC BlueTop H2B RMF or
  33. start-up problems
  34. b16 vs. b18
  35. J32 swap
  36. help code p16 ob1 gsr
  37. Need help 95 GSR OBD1 in to 98 Ek civic OBd2a
  38. turbo help
  39. vtec help please
  40. im stumped with tanny problem, help
  41. b16 oil to vtec solenoid issue
  42. es inserts on bad motor mounts???
  43. Skunk2 im on 94 gsr b18c1
  44. Spongy Brake Pedal
  45. need help please
  46. Honda newbeeee...best swap for BIG boost
  47. torque specs for 97 3.2TL
  48. Trying to lower FP's on AEM FPR...
  49. help me with this ecu
  50. ????? about a poor mans type r
  51. what whould u put in ur hatch
  52. del sol d16z6 with civic d15b7 linkage & other problems
  53. B18B swap question
  54. B20B into 98 integra
  55. 97 hx b18c type r engine swap
  56. Question????
  57. K20a exhaust info
  58. Help O2 Sensor question
  59. CR-V project
  60. What is a JDM B18C-R top speed?
  61. Need some serious help with DPFI to MPFI conversion!
  62. obd1 grs question
  63. B18C4-swapped Civic w/ tuning issues
  64. need help with wiring for swap please
  65. Si cluster swap too dim
  66. built ls
  67. Beginner; 1993 Honda Civic EX
  68. 89 accord engine swap
  69. vtec wiring
  70. Which Yr Axle To Use?
  71. Intake question
  72. JDM Dohc zc with AEM fuel rail
  73. questions on ls block rebuild for lsvtec
  74. d15b5 transmission bolt to a d16z6 motor
  75. Engine Vs Engine
  76. wiring harness..
  77. horsepower ?
  78. Question on GSR swap
  79. turbo question
  80. Mini me swap.
  81. What kind of ZC is this?? It doesn't go either....
  82. engine swap please help
  83. d16a6/y8 mini me, timing belt tensioner question.
  84. Where to get an 05 Si chipped?
  85. Jumping Tach
  86. what kinda turbo is this
  87. clutch...
  88. Piston and Crank interchange...Plz help!
  89. lsvtec question
  90. which trans?
  91. will this work safely?
  92. in need ls crankshaft and rods
  93. d16y8
  94. engine swap
  95. B18c1 jackson supercharger Stock Cluth anyone
  96. 93 with ls vtec swap
  97. Need help on a 2000 CIVIC SI
  98. Gsr is not running correct with Skunk2 pro intake mani.
  99. Shit all fuck up
  100. JDM B18c smog (high NOx)!!
  101. 3.2 cl type-s Performance Upgrades
  102. help
  103. ls/vtec issues
  104. 1985 prelude help
  105. What does this sensor do?
  106. 94 teg problems
  107. Expansive knowledge needed.
  108. 01 MDX Cold Start Misfires
  109. h22a to 3rd gen prelude
  110. nead help with ls/vtech
  111. any one ever heard of www.japanmotorimport.com ?
  112. auto to manual questions
  113. 99 civic dx to 99 ex
  114. Urgent help needed
  115. B16 idles too fast
  116. Driveshaft problem...
  117. b18b block guard/boost questions
  118. Axle fitment into S1 trans trouble
  119. adjusting fuel pressure
  120. civic 96 Fuel Line Spill with new Fuel Pump
  121. procedures on removing a b18c vtec head
  122. fuel pressure ?
  123. need help dont want it to blow
  124. Engine Change
  125. Acura RL and Acura TL rack & pinion swap!
  126. swap a D16Y7 with ?
  127. del sol- no power
  128. Turbo E-manage "tip-in" question.
  129. Recommend a good tuning shop in the south bay area?
  130. Auto repair shop in Irvine area?
  131. ls ctr rods
  132. D16Y7/Y8 VTEC Swap- Wiring Questions?
  133. J&S Ultra Safeguard tuning...
  134. quick swap question??
  135. engine revs up and down--help
  136. obd1 engine obd2 harness
  137. cam question
  138. B18b1 auto swap
  139. 89 civic hatch swap
  140. CL Type S Tranny Swap
  141. Help Needed....I'm stalling out and don't know what to do
  142. D16Y Engine swap with D15B
  143. help needed b18c5 on ITB's tuning tips
  144. D15B7 Swap with D15Z1 What will I need?
  145. wheel bearing ?
  146. gen 2 integra d series swap (high mpg)
  147. B16
  148. 93 Acura Integra charging trouble
  149. b18c5 motor swap needs help!!!
  150. Back to Honda with a new project [K24/K20 into Integra]
  151. K swap started
  152. auto to manual
  153. Question?
  154. obd2 b18b1 to jdm b18b
  155. Too much compression...help!!!
  156. Help!!! Do I need a new engine? 92 Civic EX
  157. Stock Air Breather Wanted D16Y7
  158. Zc
  159. Suspension problems on my hatch
  160. New car , b16a1 tuning ?
  161. my 200whp project
  162. d16 no start
  163. Has this been done or is it stupid and impractical??
  164. testing for leaks in ac system..
  165. 95 Civic 3DR - D15B VTEC (Idle/Acceleration Problem)
  166. Crome standard B18c map
  167. d16y8 auto to manual intake manifold swap
  168. dont know wat to do with the hatch
  169. Motor Swap question?
  170. Swap
  171. Oil pump? same for B16 and B18c?
  172. honda beater swap
  173. ***Need feed back on Wix oil filters***
  174. 91 Ls Acura Niether Fan Turns On Car Overheats Unless Bieng Air Cooled
  175. Who has the lowest price on OEM honda oil filters?
  176. 98 accord Engine replacement
  177. Help with a b16
  178. Having serious issues, please help!!
  179. Gear linkages? differant?
  180. 22mm ITR arb on a eg6?
  181. Acura 3.2 TL -Air conditioning suddenly stopped working
  182. Please Help [CARB Referee: B20* in DC2 Integra]
  183. d15 block d16y8 head
  184. Need help wiring vtec for JDM b18cR in to 2000 LS
  185. 91 civic dx 1.5 wont start t/s a lil bit HELP ME!
  186. GSR head swap
  187. suspension help
  188. B18c ITR header
  189. b18c1 clutch engagement
  190. F23A1 Idle issues
  191. what axles for a swap
  192. Need Help! No Spark 97 Prelude...
  193. VX engine into CX chassis
  194. 91 Prelude
  195. B18c Engine smoking
  196. ls /vtec idle miss fire
  197. will stock lower radiator hose fit
  198. Real world results from replacing stock intake
  199. 2002 3.2 VTEC cam timing
  200. Why does my car shake?!?!?!
  201. k-swap into 95 prelude questions
  202. condensor fan questions
  203. NGK Plug Wires Part Number?
  204. tuning my turbo gsr...
  205. Rod bearings for ITR
  206. I Need Info?
  207. map sensors
  208. h22 OBD1 in 97 Civic lx
  209. where can i find crome
  210. D15B Mini me swap
  211. K series throttle body
  212. Free OBDII software???
  213. need help
  214. Honda Engine Swap Questions Answered and More!
  215. A Few Questions... few different applications...
  216. What Intake Will Fit My Swap
  217. ITR intake mani vs skunk2 mk1??
  218. 94 civic swap
  219. B18c6 into eg6
  220. [enquiry]civic Eg6 Ecu With Tcs
  221. e manage wire up
  222. H22 into 6th gen civic???
  223. Need help!!!!!
  224. Will it work?
  225. 5 speed replacement 02 civic
  226. H22 no.9 cylinder sensor
  227. Air conditioner
  228. need help!!!
  229. tune
  230. turbo gsr prob
  231. k is it worth it
  232. d15z1 is it a possible mini me
  233. B18c build
  234. tuning
  235. H23A In 94 Integra LS 4DR
  236. Increasing stroke in my J32A2
  237. dx exhaust conversion to an ex
  238. Brake master cylinder change
  239. b16
  240. Radiator Hose
  241. Ebay boost and oil gauge and bov
  242. white smoke
  243. Engine swap Del sol
  244. e manage help!
  245. B18C Vtec not working!!!!!!
  246. Skunk2 Intake manifold
  247. D16z6 into EJ9
  248. Launch control on crome
  249. Need help with idle problem
  250. motorswap questions
go
