JDM B18c smog (high NOx)!!
Old Dec 31, 2008 | 12:33 PM
sekongen's Avatar
sekongen
Default JDM B18c smog (high NOx)!!
Hello all, in a couple of days I will be going in for my third ref appointment. I have an OBD1 JDM (P72) B18c in a 93 integra and, as the title says, it wont pass the sniffer test. A quick rundown on my setup: I have the CARB legal Skunk2 IM, stock exhaust (including the manifold), stock intake plumbing with a K&N drop in, USDM GSR ECU, and all of the correct wiring and vacuum lines hooked up, always use 91. Here's the numbers from the first test
15 mph
CO2=14.2; O2=0.6; HC Max=89, Meas=151; CO Max=0.53, Meas=0.64; NO Max=708, Meas=2627 GROSS POLLUTER
25 mph
CO2=15.0; O2=0.1; HC Max=54, Meas=69; CO Max=0.51, Meas=0.16; NO Max=746, Meas=716 Fail
OK so the first test the 15 mph failed miserably. The NOx made me a gross polluter! So after this I did a major tune up. I changed the plugs, oil, checked (and cleaned)the wires/cap/rotor (all recently changed), new cat, new NTK O2 sensor, new pcv valve/hoses and block breather, new fuel filter, ran seafoam on one tank and Lucas fuel system cleaner on another, cleaned the TB and IACV, new thermostat, and used a bottle of HEET in the fuel I used on the second test, and here are the results from all this work:
15mph
CO2=14.8; O2=0.3; HC Max=89, Meas=128; CO Max 0.53, Meas=0.34; NO Max=708, Meas=2731! GROSS POLLUTER
25 mph
CO2=15.2; O2=0.0; HC Max=54, Meas=45; CO Max=0.51, Meas=0.11; NO Max=746, Meas=737 Pass
So I'm getting a little closer, I actually passed the 25 mph test! But now what!? I Know that high combustion temps/ compression yield higher NOx numbers but timing is right at 16 degrees and with all of this new crap I figure it should pass! I have a couple theories as to what the problem is.
1. I didn't wire something correctly that wouldn't throw a code if it were bad (i.e. purge control solenoid)
2. Bad coolant temp sensor? My fan never kicks on and my system has to relieve pressure often (but never overheats/goes passed half way mark on gauge)
3. Vacuum leak somewhere? I sprayed carb cleaner anywhere and everywhere there could be a vacuum leak and there was no change in idle speed. There is however a slight surge when I hold the throttle at any rpm. My buddy brought home a smoker from his shop and we didn't see anything (car was still hot though which sometimes makes it hard to see the smoke)
4. Bad or going bad sensor? Maybe a bad MAP sensor or TPS, IAT, etc?
Sorry this is so lengthy, if you made it this far I appreciate your time. I'm just really in a bind. The DMV said they wont give me anymore extensions and I have a month left. Not to mention I'm kinda broke, so I can't afford to blindly throw money at new sensors and crap that don't need to be changed. If you have any input it would be greatly appreciated.
Thanks,
Eric
Old Jan 1, 2009 | 10:24 AM
sekongen's Avatar
sekongen
I forgot to add to theory number 4. I have an intermittent rough start. By that I mean once every one to two weeks, when I try to start my car, I will have to crank it for a while (up to about 5 seconds) and/or followd by a stumbling start. the stumble only lasts for the first seconds of the initial start up. I had a similar problem in my old teg. It had a B16 and did the same thing (more frequently and ran crappy) for months without throwing a code. Finally it thew the crank position sensor code and I just replaced the distrubutor, which in turn fixed the problem. I figure that the obd0 system is a bit more lax than the obd1 which is why it took months to recognize the problem? I just wish my current setup would throw some sort of a code to give me a smoking gun!
Old Jan 18, 2009 | 11:02 PM
sekongen's Avatar
sekongen
Used a GOOD CARB legal cat and I passed!
