b16 oil to vtec solenoid issue
Old Jun 5, 2009 | 11:10 AM
kush3d's Avatar
kush3d
Default b16 oil to vtec solenoid issue
I recently picked up a civic ek w built b16 turbo swap. Im having an issue with no oil going to the vtec solenoid. listed below are the specs on the car, any input would be greatly appreciated. My mechanic is saying its an issue with the wrong cylinder head being on there, but im curious because i assume the car was running fine at some point.
Motor/drivetrain
JG Engine dynamics Magilla Sleeved block, jdm B16a
84 mm 8.7 to 1 Cp Pistons
Eagle H beam rods W/ 3/8 inch Arp 2000 Bolts
custom thickness Cometic Head gasket .051 inch
Beautifully Hand ported 2000 Integra type R jdm Head
JG springs 11500 rated
Skunk 2 titanium retainers
Skunk 2 adjustable cam gears
Skunk 2 stage 2 cams
Civic type R manifold- port matched
Integra type r throttle body
Mugen Valve cover
RC 1000cc injectors
AEM fuel pressure regulator
Project mu fuel pressure gauge
Spoon sports ignitions wires
J's racing torque dampener
Motified Place racing/Hasport motor mounts
FULL RACE STAINLESS TURBO MANIFOLD!!!!!
TO4R Ball bearing Garrett Turbo, polished compressor housing
TIAL 44 mm wastegate
Tial 50 mm Blow off Valve
Turbo XS boost controller
HUGE Front mount Intercooler by CX racing
Chipped P28 Ecu with The Ostrich Chip Emulator Box
(allows real time fuel and ignition map changes via laptop and usb cable)
Tuned on Crome software
Inovative Wideband setup and Digital Gauge
Apexi Afc controller
Autometer Oil and boost gauges
NOS dry setup with 45 hp 60 80 100 120hp jets... 45hp in now to speed up spool
Old Jun 5, 2009 | 12:17 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Moved to Engine Swaps from Integra / ITR.
Old Jun 5, 2009 | 12:22 PM
TheOtherDave™
Apathy Kills
The specs are impressive, but they don't get you closer to solving the problem.
Which head do you have?
What ECU are you running and has it been modified?
Above all, are you sure you are getting electrical power at the VTEC solenoid?
Have you checked your oil level?
Have you inspected / cleaned the screen at the VTEC solenoid?
Old Jun 6, 2009 | 12:22 AM
kush3d's Avatar
kush3d
my mechanic was on point with what he was saying. The type r head was plugged permanently where oil goes up to the vtec solenoid meaning whoever hadthe car prior definatly wasnt even hitting vtec. i got beyond lucky and he had a ported gsr head laying around that should do the job perfectly
