d16a6/y8 mini me, timing belt tensioner question.
Tried honda-tech, no luck there so far. Any help with this is greatly appreciated. I'm having trouble with the timing belt setup for my d16a6/y8 mini me swap. I found a belt with the right amount of teeth, the a6 belt being too long, the y8 too short, I found one between the two. Anyways, even with the belt tensioner manually set all the way tight, there is still just a little more slack than I would like. Is there a belt tensioner that would bolt on to the a6 block that would be a little bigger? Or are they all the same size? Is the Y8 tensioner any larger than the A6?
