My EG Sedan turbo build...
Old 04-13-2012, 12:32 PM
dE.fUsEd
I still like honda's. :-/
dE.fUsEd's Avatar
Default My EG Sedan turbo build...
Continued from this thread:
https://www.honda-acura.net/forums/e...-to-boost.html
I've switched this project around a bunch, finally getting REAL close to completing it.
Figured I would make an actual build thread and post some pictures.
Here's the car:
*1995 Civic EX Sedan - ABS will be staying with the car.
*Paint is Championship White with a green metal flake.
The wheels in the pics are not mine. I will be throwing some Rota JMags on it for now.
I've got some GSR seats for the front right now that will be in there temporarily.
Inside of the car is currently completely stripped so I can order my new carpet.
Pics soon!
Here's the motor:
*B18C block - 83mm Benson sleeved, CP 9.1 pistons, Pauter X Beam rods, ARP hardware throughout, ACL calico coated bearings, Moroso 5.5 oil pan w/ pick up & extra gasket
*B16 head - DPR Stage 5 port work (Flows 330ci) SuperTech valvetrain nitride black coated, OEM valve stem seals & OEM Valve guides, Skunk2 Pro1 Cams w/ Skunk2 Pro titanium cam gears, Cometic headgasket
*Skunk2 Intake Manifold and Throttle body with ID 1000cc Injectors
*Full custom 3" exhaust with Vibrant Muffler and Resonator, with electronic cutout right behind the header and 3" cat.
Old 04-13-2012, 12:55 PM
dE.fUsEd
dE.fUsEd's Avatar
I had put the motor in my EG hatch.
After a tune, it made 184.2whp @ 7800rpm N/A.
Stock fuel system (injectors and pump) installed, ran out of fuel at 7800rpm's.
Video of it idling...
File Type: jpg
File Type: jpg
File Type: jpg
Old 04-13-2012, 01:06 PM
dE.fUsEd
dE.fUsEd's Avatar
I am currently pulling the motor from the hatch to put it in the sedan.
I did a compression and leak down test before I started taking it apart.
Both had very good results. Very excited to boost it.
Old 04-16-2012, 12:07 PM
dE.fUsEd
dE.fUsEd's Avatar
Just dropped $1k on parts.
Pics soon.
