- Problem Removing G3 Font Bumper
- Where is the main relay on a '90 Integra 2dr?
- Broken gas gauge
- Having Problems w/ Skunk2 Pro Series 1
- Blox type b
- '89 Teg RS Engine issues
- Kill Switch
- My buddy is looking to buy a '90 Integra LS automatic for his son
- intermittant bogging (key on/off fixes it temp.)
- lsvtec help
- cats on ebay
- 94 integra ls wont start...
- STOLEN!! red 96 gsr [Sacramento, CA... UPDATED]
- C.A.R.B. sticker
- 95' Integra turbo, opinions please
- which car did this head come from?
- which cold air intakes wud work best wit turbo
- ls to vtec
- Need seats for 96 special edition DC4.
- nephew is being givin a 95 ls (what do i look for)?
- gsr camshafts
- GSR Exhaust
- 95dB ticket anyone (Ca)?
- New rotors and pads
- Is this an Good GSR
- 02 out cat
- '01 GS-R seats stolen - NEED ADVICE, love this car.
- Shift boot install
- Do you use your teg for SHOW or laying tread?
- ITR BSQ link on "Official HAN Integra FAQ Thread "
- Help
- "Removed" intake resonator -> loud throttle
- Suspension
- Catback exhaust for my 95 integra LS? HELP
- cel problem
- bad ignition?
- Rocker Arms
- timing belt pricing
- helP CEL
- 98 + bumper conversion
- head gasket
- o2 simulator...
- Are race, light weight, seats worth the money?
- 92 TEG GS - Thumping when Steering Left and Right - During acceleration
- help plz
- Muffler
- crank shaft pulley bolt
- please help
- cel problem.
- g2 vs g3
- AEM hybrid CAI
- 1990 Integra,stock radio with anti theft?
- What are the exact differences between the 1994-1997 and 1998-2001 Integra's?
- How much $ to drop B18C5 into dc4?
- What ya think??
- Honda Badge
- axle replacement, again.
- Ticking! and new pistons.
- clutch problem agian
- Question on cams..
- Rare find Integra 00' LS
- Clutch Help!!!!!! Plz
- header question
- auto off light anyone ..??
- Front passenger side sqeak, two mechanic's opinions (pics included)
- Suspension problem
- 1995 integra no power after new timing belt?
- dh racing
- anyone with TSUDO HEADER?
- new G3 teg owner
- Leaking head gasket?
- timing belt for a b18b
- which exhaust should i get?
- skunk2 intake manifold
- Brand New
- RAYS center caps?
- Columbus tegs
- Florida runners
- Youngsta
- ac/ lose power
- 92 Ls ??
- Integra Engine Swap help
- Need Help with gsr vtec controller
- OBDII ignition timing confusion...
- Better turbo?
- wheres a good place to buy?
- Need New Jersey Info on turbos
- Guage cluster ?
- I got a clunk developing...
- Ingalls Camber Kit Users please read!!
- ABS light comes on speraticaly.
- Anyone know what this could be?
- high compression low boost
- In Need Of Upper Control Arm Bolts!!
- New steering wheel.
- Help with rims
- Question about tire sizes
- Help, one side of my car is lower than thte other!
- How about this Integra?
- whats the 1/4 time for a stock type-r
- resonator pipe?
- clutch pedal adjustment
- Door lock rattles...any ideas?
- Turn signals.... One fast.... one normal??!! wtf?
- Tein High tech lowering springs
- compression test numbers
- PS pump whining....
- Help - Adjust air conditioner compressor belt tension 1999 Integra GSR
- What Happened!?! What Do I Do Now?!?
- 94 ls redline won't go over 5500rpm
- b20 valve cover?
- Everyone else is, y not.....Almost there (boost)
- 2000 Integra GS Heating up
- Car heating up
- Motor Mount Missing
- Overheating problem only on freeways???
- electrical problem......help asap
- Oil on the Power Steering Belt?
- Inner Tie Rod thing
- Power loss/Idling issues
- I'm'a have fun installing these this weekend.
- Integra Power Stering Pump Wont Line Up With Crank Pulley...helllpp
- oxygen sensor
- Help!?
- Apexi on a 1992 4-door
- Tint Laws Chart
- cracked exhaust manifold...opinions...
- maintenance light?
- eyebrow tinting
- Got it for $800 not bad i think not at all
- Help with OBD1
- tinted tail light
- Appropriate Struts to match Eibach Pro-kit Spring
- Front end shakes when I hit 40mph or more and I hear a noise???
- RSX seats/sliders in a teg?
- passenger low beam light doesnt work....HELP
- Tokico's
- Bought springs 4 96teg, but I don't know which is which.
- exhaust leak
- Shifting sound
- Anyone have experience with NRG seats?
- Body questions...help!
- sleves???
- Boosted Gsrt Vid
- brake problem
- headgasket???
- How important is a camber kit?
- Gsr
- b18a1 vs. b18b1?
- Quieter muffler without losing power.
- heat wont turn off
- Tanabe Concept G Exhaust
- Another clutch question...
- cutting springs
- Bushing question
- boost
- I think my radiator fan is dead.
- carsound cat question
- I want to remove side moldings
- My new ride
- Odometer not working! How to fix
- ITR sway bar on 98 GSR
- Click here if you have an Autometer oil temperature gauge installed in your Integra.
- Won't start (girlfriend mad...).
- Vibration at 30+ mph
- Car overheats ALOT with A/C but air is still hot.
- Power loss
- Sway bar bushings...
- hi, new guy on the block
- Cams
- abs
- Jacking up your lowered car
- water in the hatch
- Magnaflow Street Series
- Ecu....
- Gas milage with new mods?
- my integra woes
- Adjusted my coilovers, but car didn't drop
- Answer to instability & shimmy
- First Post/New Car/Timing belt change.....
- lil problem
- replacing power steering pressure hose
- 90-93 B18A vacuum hose diagram
- Resurfacing head... Tips and more info please.
- 98 integra
- Harming The Transmission?
- MAP Sensor?
- CEL flashes... Please help
- Struts or Shocks? 96 SpecED.
- That won't Pop or Bubble
- JDM front?
- Buying an Integra
- Teg Brake Master
- Hello, Newbie here.
- please help
- Valve Covers for 1998 GSR
- Moderately considering an s2000 seat swap in my Integra.
- a/c removal
- 60k service
- New Exhaust
- stripped brake rotor retainer screw, what should i do ?
- Problems with zex..please help
- Antenna
- s2k Retrofit...
- Looking for two things!
- 87 timing belt change question
- 95 gs-r ecu
- brake master cyl for GSR
- GSR EMblem??
- Pics of gen III Teg dropped with TEIN S-tech please!
- Acura Integra Alternator
- A/C stops cooling at high speeds.
- b16 in integra
- Good cheap lowering springs 1996 special ed.
- Brand New Enkei Rims Act NOw
- 94-99 GSR vs. 00-01 GSR
- stage 3 clutch install
- humming pitch Noise when in first or second gear..
- TPS Wire
- headlight harnesses/plugs
- 1998 GSR Family
- Will these bulbs work with my tail lights?
- b18c1 is obd1 or 2
- Honda/Aisin Variable Valve Turbo Kit for Integras
- Wheel wobble on DA???
- $500 to clean piston rings?
- jus bouht 98 4dr tegra.........$1500.00
- Spitting too much fuel??
- Got Bored Tonight...Installed some T-clamps (Juicy Pics Inside)
- remote start
- B18a block b18b head, which headgasket
- shaving heads -n- boost
- acura integra sparkplug wires
- will 98 front bumper fit on a 94 integra
- boost
- How much [what springs] can you lower a 94-01 Integra before you scrape?
- Car hesitated to start today..
- TOO good to be true???!!!!???
- steering rack replacement
- wat should the compression be on a 92 gs motor
- rotor screws striped!
- new headers
- High Pitch Hum From Engine
- Ecu ?
- Brake pads replacement
- Front End?
- Hondata gasket
- What brand of Cold air?
- parts needed for b20swap
- 94 Integra RS Cold air intake install question
