Vibration at 30+ mph
Old Jul 8, 2006 | 06:15 AM
Gearhead7's Avatar
Gearhead7
Default Vibration at 30+ mph
Hi, this is my first post. Been parts of other forums but this one seems to have a technical crew that can help out with stuff. Here's my problem.
I was playing around in my car and go into a turn to quick, my camber had been off for a bit, but didnt' really notice it and my tires wore really weird. I went into the turn, lost traction, hit a median at a high rate of speed and it jacked the driver front suspension. I had to replace the steering knuckle, upper A arm, axle, Brake caliper, and rotor. I've gotten it all back together, bled the brakes. I check all torque on all bolts and we were good to go. Pin the castles bolts and put the wheels on and took her for a spin.
at about 30+ mph i start to get a really bad vibration sound. Like, the car is about to blow up, type sound. The last thing i could think it would be that I didn't check was the intermediate axle bearing. Pull the intermediate axle and the bearing feels fine. The bearing has maybe a couple mm of play which feels normal and it rolls without hesitation. I can not feel the vibration in the steering wheel at all. Just a loud vibration noise i hear. I did do a search and below are the only things I could find related, all of which seem to be no help.
Possible bad Axles?
https://www.honda-acura.net/forums/s...ediate+bearing
Alignment Issues?
See how i got into a turn really heavy and hit that side of the car hard enough to jack up alot of stuff, i am thinking it's alignment. I'm just wondering if anyone else has any suggestions that I can check before I take it up there to get it looked at. I've had both side torn completely as far as suspension and that's all I could find. All input is appreciated.
Old Jul 8, 2006 | 09:10 AM
dubcac's Avatar
dubcac
I
I would get the car aligned first. If it still shakes, go from there.
Old Jul 8, 2006 | 09:20 AM
Gearhead7's Avatar
Gearhead7
Default Resolution!
Ok, got it pulled apart last night and took a look at thing this morning. I found that the upper A arm wasn't in all the way where it bolts into the frame. It's almost a pressed fit and before I had used my hadn ratchet to tighten it. I took the air torque gun to it and got it pressed on all the way and now it runs fine. About damn time. So, that's what my fix was. I still need to get it aligned, but so far we are good!
Old Jul 10, 2006 | 06:21 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Sometimes, it is rare, but the struts can start to come free from the retaining bolt up front. This can cause wheel hop and vibration. Check to make sure those are tight.
