High Pitch Hum From Engine
Old Jun 27, 2006 | 09:54 AM
torn_phoenix's Avatar
torn_phoenix
you would
Default High Pitch Hum From Engine
I've got this annoying high pitched hum coming from the engine bay on the tranny side. It's there when I idle and I can hear it resonating off of curbs while I'm driving. I know it's not the intake because I can hear that whistle too. This is more of a high pitch humming noise. Only things I have done are AEM CAI, SK2 SS, and I replaced tranny fluid with Redline about a month ago. I noticed the noise start not long after the fluid change.
Any suggestions would help. Thanks.
Old Jun 27, 2006 | 10:23 AM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
sounds like your alternator might be going....mine went last week, i replaced it and the noise/"hum" went away along with my problem of not able to start the car.......the "hum" would rise with the acceleration and lower with lettin off the gas
Old Jun 27, 2006 | 10:50 AM
torn_phoenix
you would
This hum is pretty much constant all the time though.
Old Jun 27, 2006 | 11:48 AM
Nors's Avatar
Nors
倍力恋
Wheel bearing?
Old Jun 27, 2006 | 11:59 AM
Dorian7's Avatar
Dorian7
If you have your manual look at the tranny fluid section, it says to use only honda-acura premium transmission fluid, it says if you use anythign else use Dexron III fluid for the SHORTEST amount of time possible.... just a thought...
Old Jun 27, 2006 | 12:49 PM
torn_phoenix
you would
Redline fluid has been used by a lot of other people, even on here. So I doubt it's that but that's why I'm asking, to see if anyone else with it is having this issue.
As for wheel bearing... I hear it while idleing as soon as I start up the car...
Old Jun 27, 2006 | 11:03 PM
96BLKGSR's Avatar
96BLKGSR
My ABS unit use to make a high pitched noise when idleing. It comes and goes and sometimes after I shut it off the high-pitch sound will go for another second or two. Haven't been able to fix it yet but you could check that out if you have ABS.
Old Jun 28, 2006 | 05:40 AM
TSM's Avatar
TSM
It probably is the alt but the alt is on the drivers side only thing . All the other possabillitys wheel bearing and the tires wouldn't cause this at idle . If you take the belt of the alt and spin the pulley you should feel a grind or here noise
Old Jul 2, 2006 | 03:00 PM
torn_phoenix
you would
What exactly do I need to check for?
Old Jul 6, 2006 | 03:07 AM
torn_phoenix
you would
Default Update:Video W/Sound
Here's a short video with with audio of what I'm hearing hopefully this helps...Here
