parts needed for b20swap
Old Jun 26, 2006 | 01:29 PM
96tegls2dr's Avatar
96tegls2dr
Default parts needed for b20swap
i have located a b20 i want to purchase becasue my current motor has a few problems(fried rings and 2 bad exhaust vavles). the motor is complete with IM/EM, all sensors, tb. will i need to do anyting to drop this in? motor mounts? do i need to swap over anything form my current motor to make it work or can i use the B20 IM, distributir and such? can i use the b18 ecu?
thanks in advance!!!
Old Jun 26, 2006 | 01:46 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
Go here.....https://www.honda-acura.net/forums/s...d.php?t=239952
Hopefully this will help you out.
Old Jun 26, 2006 | 01:50 PM
96tegls2dr's Avatar
96tegls2dr
thanks man i am kinda new here and i am tryiing to get used to everything. i ahve been searching for the past few hours and i think i found the answer. i guessi should have doen that before posting. chalk it up to being a NOOB here. i have to get used to the way the forum is set up!!
thanks!!
Old Jun 26, 2006 | 02:20 PM
94blueteg's Avatar
94blueteg
screwed
whats all the fuss about b20 swaps lately? i can see that its slightly larger displacement might make some more grunt down lower in the powerband, but being that its made for use in an suv wouldnt it not make as much in the top end? isnt the b18b a better motor for a sports car by comparison?
Old Jun 26, 2006 | 02:28 PM
96tegls2dr's Avatar
96tegls2dr
that is kind of my whole situation. the b20b makes 126 hp @ 5400 rpm and 133trq @ 4300 rpms and the b18b makes 142hp @ 6300rpms and 126 trq @ 5200rpms. i am wondering if i am really going to gain anything here. i mean 6 ftlbs more but at a lower rpm and 16 less hp. see eventually i will build the motor for boost, so hopefully i am making the right decision. anyone here have an objective opinion???
Old Jun 26, 2006 | 08:43 PM
Nors's Avatar
Nors
倍力恋
B20s don't like boost very much. Atleast on stock sleeves anyways.
Old Jun 26, 2006 | 08:53 PM
dubcac's Avatar
dubcac
I
The B20Z makes 146hp @ 6400rpm. If you're going to build the motor for a decent amount of boost, I'd just get your LS resleeved and bore it to 84mm for a 2 liter.
Sure they do, you just have to tune them correctly. There are always going to be people that blow motors and try and blame it on something...almost every time it's because of the tune.
Old Jun 27, 2006 | 07:59 AM
Nors's Avatar
Nors
倍力恋
Okay let me rephrase that then. They are harder to tune reliably with stock sleeves.
Old Jun 27, 2006 | 08:44 AM
96tegls2dr's Avatar
96tegls2dr
i am looking at a b20b right now not a b20z. this is basically a replacement motor for the b18b i have now because of fried rings and valves. i will still have the b18 so i may just keep it and build it while the b20b is in the bay. this is just the cheapest alternative i have right now. i found the motor complete for a little more than $500. that is cheaper than a stock rebuild kit fo rthe b18. i was thinking about just building the b20 but since i get to keep my blown b18 ill probably just build that and use the b20 as the work horse for the time being. i do plan to build one of them most likely the b18 to push about 500-600whp. and i do know that increasing the bore on a b18 to 84-84.5mm will stroke it up to a 2.0l and give a better rod ratio for higher revs. i am just going to have to do a bunch more research before i start the build.
Old Jun 27, 2006 | 09:27 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
you need the right side bracket with the two studs from a 94-01 b18 engine to put onto the b20.
i did the swap about 2 months ago, its pretty straight forward.
