94 ls redline won't go over 5500rpm
well i own a 01 teg gs that got striped,, i put it back with a 94 ls motor but after the redline won't go over 5500rpm anyone know if it's should be like this or what .. i did search on the web they all said the b18 should have 6800rpm redline here's a link http://www.geocities.com/aloha_travis/MOV00281.MPG thankyou verymuch
Life after death
I'll tell you what I noticed, the engine temperature was about as cold as it can be. Maybe the ECM is protecting the motor by keeping the RPM's down newb. How far can you rev the motor when it's at normal operating temperature? Feel free to make another movie but without reving right after a cold start.:grinpimp:
www.ufc.com
Your car is most likely cutting out at redline due to a possible safety feature that keeps the car from redlining when in neutral. Does it cut out 5500 when driving? I am not sure if Hondas are equipped w/this kind of feature or not, however my SUV does that. You cannot sit there and rev it up or it cuts out on you.
I have a 95 gsr and Mine dose not cut out on neutral but the newer hondas do. I dont think that thats his problem. where did you get the LS motor from and dose it have mods?
I
The integras never had that feature....at least manual cars.
yes convert it to obd1 ecu i bought the Rywire OBD2b to OBD1 ECU Jumper (conversion harness)for it .. i got the swap friend a friend of mine the engine have about 70000miles on it ~~ and i check compression have like 200.190.190 200 ..let's me check if it still happen when the car heated up ~~ thank you ~~
Well what i saw from the video, the neddle went all the way down. Are you sure you have it hooked up right? And does it sound like it should at 5500 or does it sound like the redline? Maybe a video with sound would help.
no i haven't fix it yet ~~ the redline is 5500rpm won't go over even the car is heated up i don't know what cause it. and i never did any wire connection except putting the ECU Jumper.... will i guess might be the cluster itself doesn't support an obd1 ecu since my teg is an 01 i gona change the cluster see if it help ~~ thankyou guy ~
