Brake pads replacement
Old Jun 27, 2006 | 08:57 AM
jollybenitez's Avatar
jollybenitez
Default Brake pads replacement
Any suggestions on my LS '96 Teg brake pads replacement? I had it checked at an Acura service center and they estimated me at least $1000 for both rear brake pads (including brake fluid, labor, etc.). Will Pepboys, Sears or gas station service stations do for a more economical option? Should I buy brake pads and have it placed in a service center?
Would appreciate suggestions.
Thanks!
B. Jolly
Old Jun 27, 2006 | 09:04 AM
pnthr30's Avatar
pnthr30
I'd say try and do it yourself (or find a friend to help you)..........it isn't really that hard - and you can save a lot of money.
$1,000 for brakes seems crazy to me......especially if all you need is pads (and possibly rotors).
Edit: I just read you post again, they quoted you $1,000 for JUST THE REAR? WOAH! You can definitely do better than that.
I.E.) You can buy AutoZone Lifetime Warranty pads (rears) for about $25.00 - and never have to buy them again. When they wear out, just bring them in and get a new pair. Are you sure Acura didn't try to incorporate something else in their quote? If it is just pads, they must be charging over $800 in labor - for an hour's worth of work.......WTF?
Old Jun 27, 2006 | 09:46 AM
jollybenitez
They did mention that the rotor and brake "caliper" replacement are included in the quote. I'm not really familiar with all these, any suggestions/comments would really help me for opinions.
Thanks a lot!
Old Jun 27, 2006 | 10:06 AM
FooD2000's Avatar
FooD2000
Still Water
I suggest you read up on this article:
http://www.team-integra.net/sections...?ArticleID=373
Buy some tools, and do it yourself. More economically efficient, more satisfying and Fun!
Autozone offers Duralast gold which is supposed to be manufactured to meet the oem specs of the car's pads, $30-40 bucks for lifetime warrenty pads.
If you in San Diego, pm me.
Old Jun 27, 2006 | 10:45 AM
pnthr30's Avatar
pnthr30
What symptoms are your brakes showing? Are they locked? If they aren't locked/frozen, I am guessing that you probably don't need a caliper(s). As was stated before, check out the article on Team-Integra.net. Otherwise, depending on where you are, I bet you could find someone from this board to help you out - it would be MUCH less expensive than a shop, and you might even learn a thing or two. That is how everyone starts.........just start watching someone familiar with the task. Good luck!
Old Jun 27, 2006 | 07:38 PM
jollybenitez
Wow, thanks y'all guys!!! Thanks for the website, too. I'm here in Jersey and will try to look into all these and learn from your advice...
Cheers!
