Struts or Shocks? 96 SpecED.
Old Jul 4, 2006 | 11:38 AM
angelgabe's Avatar
angelgabe
Do-It-Yourselfer
Default Struts or Shocks? 96 SpecED.
I don't know what I need for my car? I have a 1996 Special Edition hatchback with a b18b1. It's been dropped with coilovers. I want to switch the coilovers out for lowering springs but I need to upgrade the dampers. My questions are, do I need shocks or struts? Is it different in the front from the back? Does the fact that my car has coilovers change what kind of dampers are in it? Do I need to change the kind of dampers I have now that I'm switching back to springs? Since I'm doing the labor myself do I need to buy any extra parts, like mounts or bushings? Last but not least, I'm under the impression that struts are shocks that have mountings for the spring to go around. Am I right or is there more to it?
Old Jul 4, 2006 | 01:40 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The terms shock, strut and dampers are readily confused.
Technically, the correct damper for your Teg is a shock.
In general, struts are designed to work both as a structural mounting point for the wheel hub and to provide a lower seat for the spring.
A common example of a strut suspension design is the DC5 RSX's front end.
The 94-01 Integra, on the other hand, has upper and lower wishbones. These locate the wheel hub and provide the spring seat, leaving the shock to operate solely as a damper.
But in general, you buy dampers by model application.
I would suggest the Koni Yellow adjustable shock and a name-brand spring like Eibach, H&R or Tein. I would also recommend buying a set of rear lower control arm bolts. It's common for the rear LCA bolts to seize and require cutting or torching to remove. An air wrench would be a great asset.
Lastly, welcome to the board. :cheers:
Old Jul 4, 2006 | 07:31 PM
dubcac's Avatar
dubcac
I
He lives in Riverside, I doubt he'll have a problem with siezed LCA bolts.
Old Jul 5, 2006 | 02:36 PM
jdm-power's Avatar
jdm-power
go with Tein H-Tech Springs and KYB adjustable shocks....thats a good setup for the money....just a suggestion....but do ur research
Old Jul 5, 2006 | 03:31 PM
angelgabe's Avatar
angelgabe
Do-It-Yourselfer
I thought H-tech were for tegs with an "H" motor swap.
Old Jul 5, 2006 | 04:07 PM
jdm-power's Avatar
jdm-power
aint sure about that theory...but i perfer the h-techs coz the drop they give is perfect if u throw in some 16's along with it....
