Hondata gasket
I have heard a butt load of good things about these and I understand how they work SO i picked one up. Hondata BLUE gasket for my B18C1. BUT I noticed that it only has one hole in it where the radiator lines go. I thought the OEM gaskets have 2 holes...wrong or nah?
ALSO im worried about the stud length, I think with my Skunk2 IMO and this thicker gasket the studs will be to short? Should i shave the IMO down a bit on the nut side or get longer studs?
I know you're supposed to cut out an extra hole on the side of the Hondata gasket so that coolant can flow through. This is if you're not doing the race install where you reroute the coolant lines from the back of the head. As far as the Hondata gasket and Skunk2 manifold setup go, I'm not sure. I wouldn't think you need longer studs.
u will need longer studs to put on a skunk2 intake with hondata gasket, i know cause i had to do that when i did mine
It works very well on JRSC'd motors.
