87 timing belt change question
Im changing my timing belt and when you line up everything on tdc on #1 to put new belt on the marks on the cam sprockets want to tilt down just alittle.if you try to line them up straight across it feels like the cams are starting to bump the valves and the cams dont want to stay there when you start putting belt on.so do you leave them tilting down alittle or hold them up as your puttin belt on.i ran into the same problem on my Crv
I went back and lined everything up and had to hold the cams in place as I put the belt on then set the tension.It started right up and purred like a kitten.When it was off It wouldnt start for S**t.
