Resurfacing head... Tips and more info please.
I just need to know a few more things about the process of getting a head job.
How long will it take the machine shop to complete the head if they resurfaced and rebuild the head. Should I use new head bolts? And will the block need to be resurfaced also?
On permanent hiatus
I just had my head resurfaced this last weekend. It took them two days to hot tank it and resurface it. I don't know how long it would take to rebuild it completely, but there was some disassembly required with mine.
I would get some new head bolts. New studs are a few dollars more, so why not upgrade? I am using Golden Eagle head studs and they are great. You will also need a new headgasket (or you could respray the old one with copper and reuse it).
The head will warp before the block does.
Why do you need to resurface it?
www.ufc.com
On permanent hiatus
Originally Posted by 96BLKGSR
Sorry to thread jack Chanratha, but I have a question for Schmoo. How much did it cost for it to be resurfaced and hot tanked? Also where did you take it? I'm in the O.C. and looking for a place to go to. I just blew my head gasket so before I put the head back on w/ a new gasket, I want to have it checked and resurfaced. Thanks
Monkey See, Monkey Do!
75bucks for hot tank and resurface?? thats cheap man.. over here in the bay area, a shop quoted me 150bucks to hot tank and resurface?? theyre crazy!!
On permanent hiatus
I changed out the head gasket and didn't really know if i had to get the head resurfaced or not so I bolt it back on and found out the hard way it needed to be resurfaced.
A friends shop told me he can do it for about $150 that's with the valves and everything.... i think.
On permanent hiatus
