95 gs-r ecu
Originally Posted by tommyhcky13
what is the best ecu to run on a 95 gs-r with alot of work done to it???
Be specific.
lots of stuff done to it, trpe r cams, pistons, headers, intake manifold, bigger throttle body, injectors, aluminum fly wheel, and probably a bunch of other stuff. i bought the car the way it sits and the guy said that it would probably run even better if it had a better ecu. i think he said it has a spoon chip in it. he said it redlines at 9500 but im kinda scared to push it that high
A chipped P28 since you are not running the dual stage GSR manifold anymore. A P72 will be more expensive and won't benefit you any more than a P28.
Take that spoon chip out. You need a chip tailored to your setup, not some high hp setup revving to 9500 with vtec set rediculously high.
vtec kicks in ate 5500 and it screams
5500 is waaaayyy too high for ITR cams. I have mine around 5150 and it is still too high.
Originally Posted by Däs Schmoo
Yeah, if you can feel it, it is engaging at the wrong part of the powerband and you are losing power.
Originally Posted by Topend
Can someone explain this. Mabye Das Schmoo. I thought you were supposed to feel it. Kinda like a way of knowing its time to get down! Anyway, im confused.
If you look at a dyno graph of improperly set vtec, you will see what I mean.
However, most tuners will set it a bit high because there is nothing like breaking the tires loose when vtec engages, so the customer is happy and they won't even be able to tell the difference, power-wise.
h:
