high compression low boost
engine
1.8L b18c1
p30 pistons
eagle rods
balanced and machined crank
itr cams w/ retainers and springs
SS valves
i have this engine setup and was wondering if i can run low boost with the application. its a air research M10 turbo i forgot the a/r ratio. the turbo has a enternal wastegate which is preset for no more then 5-7 psi. So, what do you all think?
1.8L b18c1
p30 pistons
eagle rods
SS valves
You'll need a tunable EMS and a good tuner, but it can be done. Make sure you get some NGK BKR7E copper plugs and gap them appropriately. A good tuner should have no problem...I've seen people run 11.5+:1.
