please help
Old Jul 3, 2006 | 11:47 AM
jamie9500's Avatar
jamie9500
Default please help
hey everyone i need help. I own a 95 intgera gsr. about six months ago i went out to start it and it wouldnt start just make a clicking noise didint even try to turn over. So i bought a new battery and it started right up. Well today i went out to start it and same thing. Someone told me it was the starter. all my lights still come on but nothing the positive side of my battery terminal is corodid a little bit what looks like greenish powder what should i use to clean them off then what is my next step thank u.
Old Jul 3, 2006 | 12:09 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Welcome to the board. :cheers:
The post corrosion is easy to remove with either a dry metal scrubbing pad or better yet.. a wire brush. To stop the corrosion from re-forming, buy a set of anti-corrosion terminal pads at your local auto parts store. Also, don't forget to remove the corrosion from the battery clamps as well.
:thinking: The second issue sounds more like a drain on the electrical system.
Given the age of your car, I'm suspicious about the health of your alternator. If it's not putting out sufficient voltage to recharge the battery as you drive, a new battery will lose charge over time.
Remove the corrosion first and see if the car starts. If not, I'd remove your alternator and have it tested at Auto Zone or some other shop to ensure that it's operating to spec.
Old Jul 3, 2006 | 12:18 PM
Integra89's Avatar
Integra89
COKE A COLA!!!.....worked for my lawn mower
Old Jul 4, 2006 | 12:15 AM
vtec4clyfury's Avatar
vtec4clyfury
Geese!
if you have a local garage near you have take your car to them and have them check the amperage on your alternator. They'll probably stick a VAT-40 or something near that on there and it will them the amperage. I know autozone doesn't have a vat-40.......well maybe they do but i seriouosly doubt any of them are smart enough to use it the correct way. Just try a local auto shop, i'm sure someone can clamp an amperage clamp on the wire and find out the charging state.
Old Jul 4, 2006 | 11:21 PM
jesusublime99's Avatar
jesusublime99
This happened on my '95 GSR...I took out my starter and had it tested at Autozone. Result = bad starter. I replaced the battery when I installed the new starter too.
Old Jul 5, 2006 | 06:58 AM
GSRRacer95's Avatar
GSRRacer95
Fight On!
My guess is the starter. Save yourself some money and just replace the starter contacts. The same thing happened to me about 2 months ago. Most import starters are gear reduced and don't ever wear out. You can buy new contacts for like $8.
Old Jul 5, 2006 | 07:05 AM
90CvcDX's Avatar
90CvcDX
kekeke
When you turn the key to start the car, does it make one click and then the lights go dead? If so it could be the wire that runs from the positive battery terminal to your starter is loose or corroded, happened to a few people i know including myself twice... just check to see if the wire is loose or corroded, clean it off or cut down the wire to get fresh wire and tighten up the terminal thing as much as you can. If this fails then yeh go buy a new starter... Always try to save the expensive choices for last.
