- 94 gsr worth it?
- Quick answer!!! rotors and callipers
- Painting stock 94 LS
- No air filter = bad
- 96 gsr oem clock
- Gsr pulls to the left when accelerating...
- Exhaust piping.....
- what do stock 94 LS wheels look like?
- How come ITR doesn't come with roof??
- Side markers are loose
- Full-Race
- Problem with cylinder #4?
- Vafc 2 Help!!!
- squeeky noise from front end maybe starter?
- Choosing a ECU Chip for my 94 LS
- ECU Swaps
- Anybody here have 99-00 si wheels on their integra?
- LS block with GSR head?
- looking for a distributor
- OEM muffler size??
- Vtec/non Vtec
- gsr w/ type r pistons, need advice
- Could a Teg FWD be a Drift Car
- 1991+ Integra Model info
- Console Switch pop-outs?
- rotors and brake pads
- want to turbo or should i put my jrsc from my gsr
- set up 4 boost¿?¿?
- 91 teggy, need help
- side markers
- Reverse Rubbing!!
- opinions on spark issues
- aight i got a bubble in my tire
- help with removing alternator
- Axle replacement
- crank pully
- Engine Electrical Troubles...
- Last Resort: What is Wrong With My GSR?
- Front Door Handle Removal
- What is the purpose of this site????
- Leg room!
- Code 65
- Power Steering Problem?
- 91 integra rs cv joint replacement
- Need new IACV or FITV for good price, any sites/vendors?
- american OEM all red taillights + OEM amber front-corner-lights (DC2, year 2000)
- Replacing side mirrors, what to get?
- planning to boost with jrsc on 00 gsr
- 92' gsr manual transmission needed
- GSR IM/TB - be the Acura Sage I need
- Stock Integra vs Stock Accords?
- B18a
- candy apple red ?? help
- 2000 GSR throttle body on my 91 Teg LS
- Can someone tell me which is a better tire out of these
- Buying a GSR
- obd1 p28 to obd2 p73 ???s
- Anyone with a Comptech combo sway/tie bar seen this?
- How to increase my mpg?
- Clicking noise
- can an integra make flames or like a spark while you shift or down shift?
- what motors fit in a gsr?
- how much increase in mpg do u get with header and intake?
- what is better?
- Anyone know how to fix a headlight that goof off has been used on?
- After 4 months of waiting...
- how can i get the most power out of my gsr supercharged
- '94 Integra auto tranny acting up
- Tire recommendations?
- 98 GSR getting 16mpg??????
- engine swap suggestion
- getting crappy gas mileage
- Mods for AT till I get a Manual
- Trade AT for M tranny cost
- choice for ignition wires
- weird electrical trouble
- Don't buy IAT Modules
- Looking For Paint
- Integra Ls 2000 35k miles worth keeping
- speedometer cable
- Will a 99 Civic SI Cat fit a 98 GSR?
- Air Horn only hums
- Rear Washer Fluid
- Bronze Rota Slipsteam
- Acura Integra GS/LS or 4th gn Lude
- 94 integ LS underdrive pulleys
- front turn signal wires n crap. 94 integ ls
- Hood Latch?
- condensation inside front bumper lens
- Build The Ls Engine Up
- Could A AUTO BE FASTER THAN MANUAL
- turn signal bulbs
- possible future acura owner....please help
- holy crap!
- LS factory alarm
- How much is a '98 LS worth with a salvage title?
- 95 Integra - Help with replacing the indicator "D" drive bulb in the dashboard
- Help with a problem
- another A/C thread
- Installing an MSD shouldn't be that hard.
- Funny idle
- B20z into dc4 questions?
- anyone with skunk 2 stage 1 cams on gsr???
- Tightened belts still squealing?ALTERNATOR(could it be)
- LS/VTEC Questions...
- "Car buffs" report.. help me out...
- fast way to sup up a non vtec 1.8l
- 2000 integra LS Newbie with ?? on modifications
- missing bumper?
- IACV Cleaning...
- Suspension mods....Alignment Problems.
- what is the best intake manifold for a 2000 ls
- is this good???
- dc2 decal dimensions
- vtec head?¿?¿?
- help me get my secondaries!
- B18C Tranny Trublz
- VTEC wiring OBD0 to OBD1
- That quality feel is what i'm after
- What do you guys think of my drop?
- Beginning Tuner help
- OBX intake manifold?
- Help bad plug
- Put on my Falken Azeni's
- Diagram ECU Honda Integra 1.8 LS
- oolah
- Turbo, supercharger, N/A¿?¿?¿ what to do
- whirrrr noise
- Sound like a flooded car???
- unpredicatbale failure to start
- Actual price for a 95 GS-R?
- Gsr - Ls
- Gasket Alternatives..
- tuning help!!
- Auto to manual conversion
- i installed my stainless brake lines...
- Why Does my Wheel Do This?
- How long do you have to disconnect battery to make ECU reset?
- Jackson Racing SuperCharger
- Massive Wobbling after driveshaft slid out of inboard joint
- throttle body questions
- Rear sway bar question...
- adjusting tokico coilovers
- Suspension install problem, Please Help!
- Muffler Tips
- I got new seats!
- Check Engine Light On!! Please help!!
- Starting problem
- Looking at 98 teg, engine prob?
- nj/philly area....?
- Need Sunroof Help!!!!
- is tokico hp or illuminas a better shock to get?
- 'AEM-cai' - First Mod for my 'ITR!'
- Sticky doors
- Advance Ignition Timing Question
- New exedy clutch doesn't fully engage/slips
- Help...Idle rpm see-sawing from 1000-2500rpm...WHY?
- Clutch break in.....
- Please Read!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- ls 2 si swap??
- Does anybody notice tight steering wheel with their integra?
- Starting Problems in heat
- I need help !! (omni power)
- 98 hatch speakers question
- Generic? IM Heat Shield Gasket?
- What are all the essential components of a turbo for my GSR?
- Gsr all over the road on breaking???
- found a guy to rebuild
- Transmission shaft diameters
- Acura Integra GSR Noise PLEASE HELP
- Braking affecting idle speed?
- Special Edition
- Paintin Mah Car
- Momo Steering Wheel and Cruise Control
- Buying 98 Teg GSR, Opinions?
- Throttle body spacers? Votex? Helix?
- California smog help
- timing question
- Anyone know the differences between ls and gsr drag3 kits?
- Powder Coating...
- Hin
- VERY strange VTEC Solenoid *PICS*
- *WANTED* GS-R engine
- paying somebody else to install ES hyperflex kit
- three of a kind integs. what paint?
- timing question
- CompTech Cat issues
- replaced missing CEL bulb, checked codes
- help finding gsr
- Should I run Synthetic Oil?
- J's Racing or Comptech???
- more boost on turbo integra type r
- ls/vtec questions
- 100% Financing on an R
- 90-93 teg fender molding trim black or chrome?
- DC2 LOWERING SPRINGs (NOT COILS)
- replacing ls for gsr tranny
- buzzing sound @ 3k RPM
- Non Starting Problem
- prices on cf hoods...
- just ordered my ES shifter bushings!
- brake messed up?
- Building your own SR Intake
- Looking for Info on Skunk2 Springs....
- Thanks Mistacee! New Wheels :D
- strange sound coming from BOV
- '98-'01 OEM Fog Light Install
- Sway bar question
- My Antenna is weird......
- integra/ civic interchange?
- strange/fast idle, please help
- Opinion on tail lights...
- GSR handle like Type R
- lightweight rim suggestions
- Camshaft question.....
- Apexi WS Exhaust
- turbo for 1250?
- need advice on forced indution
- Cheap thrills for my ride (newb ?'s)
- JDM ITR Headlight Wiring Diagram?
- Code 43?
- Will 87 octane regular unlead cause engine to sputter like a motorcycle?
- i got 170 bucks
- My 97 LS (pics)
- Full belt replacement...
- Passport 8500
- how do I replace the blower?
- Got parts... now need to figure out how
- sticky gears..
- Spring fit???
- Resonator
- RPM's Auto trans 92 Integra
- Codes # 22 and 54
- Question on Big brake kit.
- Need help with GSR PLEASE!!!!
- '98 GSR: Skunk2 coilovers on stock struts
- 93 integra ls ac problem
- exhaust
- Hunting Idle and drive belts...
- Anyone ever notice a loss in power after installing an air bypass valve?
- 99 Integra LS
- What do you think?
- just bought a '96 gsr.....
- Is Hayame a good brand? Anyone heard anything or running a Hayame exhaust?
- Im sure we have all had this problem
- Mods
- safe boost level
- Is Something Missing???
