Clicking noise
Old Apr 15, 2005 | 09:24 AM
wolfmann's Avatar
wolfmann
Default Clicking noise
I will try to explain this the best i can. A couple of weeks ago I changed my oil. When i was finished i started up my car and let it run. It started making a clicking noise and i shut off the engine. I started it again and it still made the clicking so I shut if off and left it for a day. Well when i went back to it and started it the next day it was fine. I drove it for about fifteen minutes and it started clicking again so it doesnt do it all of the time. It makes the noise up until about 1500 rpm and when i go higher then that it stops clicking. What could this be? I also notice that my exhaust is spitting out some water.
Old Apr 15, 2005 | 11:04 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Have you done a valve adjustment recently? Other than that, I wouldn't know unless I was there and could see the problem.
Water is normal when the car is first warming up.
Old Apr 15, 2005 | 12:00 PM
EvanG23's Avatar
EvanG23
Kid w/ No Money
How loud is the clicking? I know that using fuel with a lower than recommended octane level can cause some minor clicking... but integras use regular so you would've had to have gotten some crap gas... but your problem doesn't sound like that, because it only does it at certain times... try to make some more observations and give more info.
I'm picturing the boat engine in Jaws when the black smoke is pouring out of the hatch... is it that bad or just minor?
Old Apr 15, 2005 | 03:17 PM
'93TurboD's Avatar
'93TurboD
5-finger discount :rick:
You may have done this already, but, check your oil level.
Old Apr 15, 2005 | 03:51 PM
dubcac's Avatar
dubcac
I
Sounds like valve tap to me, it's normal. A valve adjustment would help
Old Apr 15, 2005 | 10:41 PM
OilCanBoyd's Avatar
OilCanBoyd
Did you use the same oil in the car? Same brand and weight as the last change. Cars will respond to different oils in different ways. Sounds normal to me.
Old Apr 18, 2005 | 11:13 AM
wolfmann's Avatar
wolfmann
yeah i found the problem. It was the valves. i just need to take it into the shop. thanks for the help
Old Apr 19, 2005 | 07:41 PM
Integra94LS's Avatar
Integra94LS
i think i may have the same problem except mine does it when its just idling, i hear it the most when i first start up my car. but even after its been drivin i still hear it, if i have no music on and the windows shut i can still hear it too. its a clicking sound that just keeps going and going but its not too loud. my mechanic told me its just the vavles and its normal but i know that, i think i need a vavle adjustment too. if thats what i need how much does that cost to have done?
Old Apr 19, 2005 | 10:16 PM
Provocateur
On permanent hiatus
Why don't you just do it yourself and save yourself over $100?
http://www.c-speedracing.com/howto/v...alveadjust.php
It isn't hard, just tedious. But I would get it fixed whether or not you decide to do it yourself.
Old Apr 21, 2005 | 11:10 AM
Integra94LS
i would do that but don't have the tools for it or really any experience and i'm afraid of mess anything up. also my car has been making this clicking noise for the last 15 - 20k miles on my car, is this bad and will it get worse or do anymore damage?
