Turbo, supercharger, N/A¿?¿?¿ what to do
Old Apr 10, 2005 | 04:34 PM
rpmman22's Avatar
rpmman22
Default Turbo, supercharger, N/A¿?¿?¿ what to do
ok i have a 94 acura integra gsr. it has type-r cams,aem cold air intake, dc 4-1 headers, 2 1/4 cat back exhuast with no cat, and a mugen chip. i want to build the car for 1/4 mile and im wondering what would be the best with the set up i have already.supercharging it turbo or N/A please help im really confused
Old Apr 10, 2005 | 04:37 PM
ISP James's Avatar
ISP James
DAMIMRED
how much do you want to spend?
what are your goals?
with f/i, a lower compression ratio is more desirable. of course, gs-r has a relatively high c/r. you can run low boost (probably 6-8 lbs) with a s/c or a turbo
if you're looking to spend a little less and not trying run 12's you can make a strong and fast n/a car.
Old Apr 10, 2005 | 05:02 PM
honura's Avatar
honura
Seni
Yeah like James said. i would go boost (6-7psi) Trust me you'll love it! I am currently running a t3/t4 setup on bone stock Ls and I will toost most mild built gsr,type r out there. Good luck either way you go you will be good.
Old Apr 10, 2005 | 07:01 PM
rpmman22's Avatar
rpmman22
well it looks like i would have to spend around 3000 to get a turbo or supercharger i think unless i can find something for cheaper but thats around what i want to spend if i did either of those what would i have to change up on my car to make it handle the boost it has like 107000 on the engine. my goals are i think it would be nice to get into the 12's would i be close with a s/c or turbo¿
Old Apr 10, 2005 | 07:29 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
With a big enough turbo and a rebuilt engine to handle the boost, you will hit 12s for a lot less work and money than going N/A. I run 8 psi daily and hit high 13's, low 14's and I am still running stock internals with 140k on the odometer.
For boost you need stronger con rods, lower compression pistons, and most importantly, upgraded fueling and fuel management. A standalone ECU is the best option you can go with, so make sure you have enough money left over for the installation and tuning of either a Hondata system or Uberdata if you do it yourself.
Old Apr 10, 2005 | 07:32 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I need to have a canned response to these questions as often as they are asked. :wtc:
Old Apr 10, 2005 | 07:33 PM
rpmman22's Avatar
rpmman22
so if i run like 8 i should be ok with the stock internals and the rest or what i have
Old Apr 10, 2005 | 07:54 PM
hakjai's Avatar
hakjai
with proper tuning yes, and you would have to sell your intake and headers if you go turbo, your chip would probably be useless too if you get a standalone
Old Apr 10, 2005 | 07:59 PM
westcoaststyle
I wouldn't run any kind of chip that wasn't specifically made to work with FI if you go that direction. It could lean you out and very much damage the engine. And yes, you will not need to be able to use your intake or headER if you go turbo.
Old Apr 10, 2005 | 08:34 PM
honura's Avatar
honura
Seni
Well with the right tuner you can go upto 8-10 psi and have it hit crazy #'s. Search around and DO NOT jump into either option unless you have searched and really really feel good about what your gonna do. I learn the hard way.
