Turbo, supercharger, N/A¿?¿?¿ what to do
Old Apr 11, 2005 | 07:52 PM
rpmman22's Avatar
rpmman22
Originally Posted by jsief85
it's been said too from many people that integras tend to respond better to N/A tune anyway, you could stroker the engine and increase displacement....ive seen some decent kits for around 2-2.5 k...
where have u seen these kits
Old Apr 11, 2005 | 08:05 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
http://www.google.com/search?sourcei...&q=gsr+stroker
Google, who woulda thunk it? :shocked:
Old Apr 11, 2005 | 08:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by g10 526
If i remember correctly the greddy kit also didnt come with a fuel pump, rail, filter which is good to have with boost. Another thing to upgrade would be your clutch (although your stock one should last for a while depending on the wear)
I am running the stock fuel pump and rail. There is no reason to upgrade the rail since the stock one can easily support 500 hp. I plan on upgrading the fuel pump since I plan on bumping the boost to 10 psi tuned with uberdata. Right now, it has no problems with the stock pump.
I want to replace my clutch but I just got it replaced less than a year ago. Once I wear it out, I will throw in a ACT HDSS with a lightweight flywheel of some sort.
I don't know what you are referring to when you say filter.
Old Apr 12, 2005 | 06:30 AM
westcoaststyle
Prolly fuel filter. My motor was stripped of the rail and injectors when I got it so I just upgraded right there instead of finding an OEM rail. I run an AEM rail, AEM filter, Walbro 255lph LP pump (soon upgrading to HP), 550 RC's, and tuned with Hondata. I really need to sit down and do a write up on everything you need to run a turbo.
Old Apr 12, 2005 | 10:12 AM
carta79's Avatar
carta79
Life after death
Why would you stroke a motor that has a low rod ratio to begin with? I would get the motor bored out and resleeved to hit 2.0L instead of purchasing a stroker kit.
Old Apr 12, 2005 | 11:28 AM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
here's a quick fix.. New clutch, cams and cam gears, skunk2 intake manifold and spray it, 80 shots or 75 and forget about it most gsr's i've seen run this setup with a "ok" driver mange low 13's high 12's and hit around 280 whp without even building the motor..
Old Apr 12, 2005 | 11:29 AM
IntegraType-R
ALL MOTOR KING
I can set you up a tuning for a price, cause so far the car's i've tuned have gainned a good amount of hp around 20-28 hp just from TUNING!.. engine mangement is the best mod you could ever do..
Old Apr 12, 2005 | 12:54 PM
Snoopy's Avatar
Snoopy
been there done that
IMO, stroker kits are a waste. for a little more, you can have your block rebuilt with brand new forged internals, sleeved, in any bore size and compression you want.
Old Apr 13, 2005 | 05:49 PM
rpmman22's Avatar
rpmman22
A price huh¿ what kind of a price are we talking about¿ and what would do exactly¿
Old Apr 13, 2005 | 09:14 PM
Provocateur
On permanent hiatus
Tuning a stock car will not get you anywhere but broke. Unless you have a sick N/A setup or are using forced induction of some kind, you don't need it.
