Generic? IM Heat Shield Gasket?
Old Apr 7, 2005 | 04:28 PM
themilman's Avatar
themilman
Wookie Nation
Default Generic? IM Heat Shield Gasket?
Anybody heard of these or know anything about them? I can't find anything.
Intake Manifold Heat Shield Gasket +HP versus-Hondata
Recon Engineering More Power for Less Money GSR RSX
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Apr 7, 2005 | 06:15 PM
EvanG23's Avatar
EvanG23
Kid w/ No Money
I've heard a lot about them... try searching here. I doubt if they would have much of an effect... maybe a couple hp but post whatever you find out...
Old Apr 7, 2005 | 06:48 PM
carta79's Avatar
carta79
Life after death
I have yet to understand why people put generic parts on their car. Why not spring for a Hondata gasket? Does the extra twenty five dollars break the piggy bank?
Old Apr 7, 2005 | 07:37 PM
newgsrdriver's Avatar
newgsrdriver
No but if a piece of plastic is a piece of plastic, why not save the $25?
I dont know of any differences between Hondata or the other multitude of copies...anyone else have any information?
As for picking up power, not really...its moreso designed to prevent manifold heat soak, therefore decreasing IATs slightly in a situation where heatsoak would occur.
That, combined with a few other simple mods may allow a tuner to be a bit more aggressive...but other than that I wouldnt expect much.
Old Apr 7, 2005 | 07:40 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
My only reservation would be the materials used. If a cheap plastic is used it could easily melt with the temperatures of the engine considering its placement. I currently use a Hondata gasket and will be replacing it fairly soon with another Hondata gasket.
Consider tires in the same respect. You can buy a brand name for $XX.XX/ea or some cheap-o version for $50/ea less. It's all rubber, right? Just a different perspective on a similar set of parameters.
Old Apr 7, 2005 | 08:27 PM
themilman's Avatar
themilman
Wookie Nation
Thanks guys, I understand the cheapo vs. proven brand pretty well, you get what you pay for, just hunting for details. I've found a lot about IM heat shields on this site, there are quite a few companies out there, hondata, outlaw, etc., and all seem to have good reps. I'll keep digging on these guys and see if I find out anything worth posting.
Old Apr 7, 2005 | 09:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It would probably be worth trying just because it is so cheap. Good luck getting the stock cork one off. Mine melted to my head and required clever use of a dremel to get all of it off.
Old Apr 7, 2005 | 10:27 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
tell us how it goes and how the install looks like
im interested in how it bolts on
Old Apr 7, 2005 | 11:14 PM
1turbodc2's Avatar
1turbodc2
got boost?
I have the hondata gasket in my 01 gsr with my skunk2 intake, the only problem i had was the studs from the cyclinder head, weren't long enough with this setup so i have to change the studs to a little bit longer ones.
Old Apr 8, 2005 | 06:37 AM
westcoaststyle
Ya, I just went with bolts. Good catch man, I'd forgotten about that.
