Massive Wobbling after driveshaft slid out of inboard joint
Old Apr 9, 2005 | 08:05 PM
Inacurals's Avatar
Inacurals
Honda Hoar
Default Massive Wobbling after driveshaft slid out of inboard joint
The boot has been ripped awhile and when i was installing my camber kit the knuckle w/ the rollers slipped out of the inner joint and was pain to get back in.
I got it to go back in and i drove it apprx 10 miles and was fine then outta nowhere RSide started wobbling hard and couldnt go 30+mph. So what do i need just the RSide drive shaft and boots or is there a fix???
Old Apr 9, 2005 | 09:42 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I had a similar problem with an inboard joint of mine. Turns out the "remanufactured" driveshaft I replaced my stock axle with had a bad inboard joint. It wasn't as bad as what you are describing but it sounds like the same problem. The easiest way to fix that would be to get a new driveshaft. You can rebuild the joint and re-boot it but it is hardly worth the effort considering axles go for like $60.
Old Apr 10, 2005 | 11:00 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:werd: to Shmoo. That axle is toast. Replace it.
