Will 87 octane regular unlead cause engine to sputter like a motorcycle?
I just switched out my civic's 1.5L engine to a GSR. It haven't used up all the unleaded gasoline in it...and it's making sputtering noise like a motorcycle. Could that be the cause or something else? I noticed the rpm doesn't idle like normal...it goes up and down sometimes. Thanks in advance.
GSR motor takes 91+
That could be the problem. An easy way to test it is to dump a bottle of octane booster in the tank, or depending on how much gas you have left, fill it with the highest grade you can find.
Yes, you are detonating. Go fill the rest of the tank with 91...if you have a full tank, drain it.
Originally Posted by lilgrasshopper
where can I get octane booster...I have a lil bit over 1/2 a tank left. Where I"m from..I can only get 91 octane.
just go to autozone, pepboys, etc... theyll have it
Hopefully, nothing was damaged. Toasted pistons, rings, valves, etc. could have occurred and would be totally crappy on a new engine. Just make sure that you do something about the crappy gas in the tank.
