set up 4 boost¿?¿?
Old Apr 17, 2005 | 08:21 PM
integra333's Avatar
integra333
Default set up 4 boost¿?¿?
well i have finally made my decision and want to go with boost, im wondering what i will have to do to my block so it can handle high psi, its a a b18a/b help me out please!
Old Apr 17, 2005 | 08:34 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
How high and with how large of a turbo?
Your first step should be a compression and leakdown test to determine if your rings can handle the boost.
Old Apr 17, 2005 | 08:48 PM
integra333's Avatar
integra333
well im planning on rebuilding it because it has 200200 miles on it and im wondering how i should rebuild and what is a good kit it 25psi¿
Old Apr 17, 2005 | 08:51 PM
Provocateur
On permanent hiatus
With that much boost, you need to resleeve the block, put in some stronger rods, low compression pistons, strengthen the bottom end a good amount, etc.
Why 25 psi? 25 psi can be completely different things with different sized turbos. You need to decide your power goals before you automatically decide you want to boost 25 psi so that you can find a properly sized turbo that can meet your power goals with much less boost.
Old Apr 17, 2005 | 08:56 PM
integra333's Avatar
integra333
well what would be a good size turbo/psi for getting into the 13-14 range 1/4
Old Apr 17, 2005 | 09:00 PM
Provocateur
On permanent hiatus
Shit dude, my little Greddy kit pushing 8 psi and ~215 whp will run low 14s/high 13s. Keep in mind that is with a GSR motor. You don't need 25 psi to get those sort of times. A RevHard or Drag kit with a T3/T4 hybrid turbo will easily get you those sort of times without going over 10 psi on your LS motor. I would put in some low compression pistons and rods since you are rebuilding it anyway so you can handle extra boost down the road if you so choose.
Old Apr 18, 2005 | 01:34 PM
integra333's Avatar
integra333
do you know were i could get one of these kits?
and should i get different cams and cam gears for my ls¿
does a vtec help at all with a turbo?¿
Old Apr 18, 2005 | 02:02 PM
Provocateur
On permanent hiatus
Yes, VTEC helps.
No, don't get cams. Cam gears are fine but stock cams will be better than any aftermarket cam for turbo.
Ebay, www.horsepowerfreaks.com, www.nolimitmotorsport.com, etc. Do a search on yahoo and you will be bound to find a nice kit.
Old Apr 18, 2005 | 02:13 PM
sherwood's Avatar
sherwood
I missed Sean
vtec will always help cause it's just basically a better cam profile for higher RPM's it applies to everything and not just NA
Old Apr 18, 2005 | 02:56 PM
integra333's Avatar
integra333
cool should i get a turbo then do the ls/vtec converson or is it not worth it¿
will it ever beat a turbo grs or am i asking too much
