- Idle Problem - 98 Civic DX - Please Help!
- anybody heard anything abou
- Ground Controls?
- Lights Bulb on Climate
- Water Temp Gauge?
- clicking noise when braking....
- Wiring Diagram?
- LS swap in an EG
- Bolts
- :yay: for today
- Low Oil Pressure Light
- Engine Check-Up
- Hmmm...got a free bumper...
- rev limiter
- OMG!! Would this really work!! LOL
- now..what hell is wrong with this lil picture?
- Good SIte URL's with good Turbo kit Deals???
- Air Conditioning System stuff
- Apexi VAFC
- what happens when...
- Dyno'd the CX
- ***Immediate Attention Please: oil pan on a b16a, dented, oil pickup?
- dumb question...
- Lookie lookie...
- Removing seats
- Exhaust Question
- Block Heaters
- >>NEUSPEED® Race Springs???<<
- want to see if this is ok
- Civic Repaint costs
- Best EGT?
- Interior
- installing fog lights
- what color car is this?
- DOH! car didn't pass inspection.
- Need some help on spring questions...
- Needed: Del Sol Passenger corner light and head light unit
- Wheels/2004 Civic
- Megan?
- New Project...
- Good shop in Socal...
- quick question stock ecu to run a D16Z6
- Bolt Mesurements
- 92EG6's Custom Sway Bar Brackets!!!
- Ok maybe I said something wrong!
- 2002 Civic CD factory player SUCKS!
- Civic with LS HARD TO SHIFT?
- hp 98 civic lx and ex
- Finally got a hatch!!!
- ITR engine mounts vs. GSR mounts
- NEED HELP with smog please
- car jerks violently
- 2004 Civic Coupe EX, Looking for parts...
- about to autocross for first time, anything I should do?
- Megan Racing LCA's
- Some cool pics from this past weekend.
- Del Sol / EG Hatch weight comparison
- civic 1995 immobilizer help
- 95 Civic EX won't start.. help?
- 92 civic tail light help
- Clutch Question! How bad is this... Need input!
- Who here powdercoats?
- Crank Pully, Un-Balanced, Problem?
- which axels to use?
- tranny swap help
- 99 tail lights on 97
- Rattle, rattle…
- drum to disc?
- Keep b2 cam or go w/b7's?
- 1157 92 civic bulbs
- this weekends project pics....(*56k make a sandwich)
- son of a bich, hondata problem....
- What does Salvage Title Theft Recovery really mean??
- b16 a bog????????/
- b16 into 5th gen civic question
- Transmission compatibility question?
- civic ex vs. lx
- Greetings, first time buyer here!
- HAN members: Falken Azenis Groupbuy 205/50/
- turbo CEL question
- 94 Civic Overheating...I think it's toast.
- Exhaust For Itr Swap?
- Help help. question about custom exhaust pipes
- Rattling noise coming from the rear wheels after install...
- xenon bulbs piaa vs nokya
- rear suspension
- Tower Braces
- What should I do with old tires?
- apexi afc install
- 2003 Civic Sedan floor/firewall passages?
- n00b question
- Radiator gap:1.1 or 1.2 for Civic?
- HELP! Installing XM radio
- headlight bulb question
- OBDII: How to Set Evaporative I/M Monitor?
- Short Shifter....Single bend, double bend...
- quick question
- question about uneven lowering
- Installing XENON WHITE light bulbs...
- Sway Bar Install 92 civic
- Tune Up Time
- OEM Sway Bars Install
- accident ? about seatbelts
- 98 B18 swap
- 2002 Civic LX Factory CD Player Replacement
- Sway Bar Install Help
- IAB solenoid
- TPS sensor question
- air in cooling system? d16y8
- It has begun...
- tire rub
- anybody know what belt..
- weird problem
- Digging up Old Demons (My Brakes)
- new toy!!
- Any comments about this?
- What needs to be changed
- very unusual motor swap ????
- JDM D15 -vs- USDM D16Z6
- damn radiator
- Did 97 EX come with black interior?
- Shocks/struts/dampeners :)
- Want to do your own alignment - cheap?
- b18C5 SWAP
- B18C1 Motor Swap!!!!????
- steering wheel removal
- Koni Yellows
- help with neuspeed springs...
- Need opinions on what muffler to get
- question about 97 ex braking
- Rim Question
- Big break kits...
- 2002 SI Seats in 2000 DX Hatch
- PA in a civic?
- Air conditioner ......
- STUMPED! Ignition Starting problem-No spark with dizzy/main relay/fuel pump OK
- STUMPED! Ignition Starting problem off of a swap
- Removing front bumper? 2001-2003
- B16a2 In to a 1989 honda civic
- B16-b18
- Psi is equal to....
- Cost of 2004 Civic Hybrid - CVT
- n00b in need of help
- tire opinions
- Header gasket problems. :(
- Climate Control acting weird...
- How to seal a crack
- suspension DIY
- Where does this go!!
- Springs Question
- What do ya think about stillen front honest opinion
- 2000 Civic Ex Exhaust Package
- Ohh Shiznitz!!!
- Shifter Issues ??
- Check these out!!!!
- gettin ready for summer
- What kind of MC and Brake Booster do I need?
- Aftermarket wheel
- all possible vac leak locations
- CTR front sway bar install on EK civic
- Trying to find rear speaker panels for a 92 CX
- How to bleed brakes?
- squeak from brakes
- CAI Vs. V2
- different clutch pedal?
- car hesitating in first and second
- AEM Cam Gear
- Will LS Transmission Fit and Work right on a B16A2 Engine
- Just Curious...
- DX motor with EX tranny
- proper ecu
- when turning...
- cold air intake
- LS Swap Fuel System
- 250 whp
- *PiCs* All of this is goin on the Si tmrw...*PiCs*
- Wanted DelSols
- nice turbo kit
- spark plugs of choice
- 94 Civic Si Help
- swap idling issues and CEL
- engine swap
- my sunroof is fugged
- Cam Problem Need Help
- I think I hate my car....
- id'ind unknown springs
- B series IACV
- Timing belt change?
- swapping parts from EJ/K to EG
- Help!! How To Remove Fender Off 95 Civic
- Spring Install & KYB AGX Settings
- how to clean iacv
- throttle cable/linkage of 99' si vs. throttle cable linkage of 98' lx civic
- Engine fan
- Swap Is Complete Almost...
- Just did a tranny conversion
- Anyone dealt with wheelsnext.com?
- 2000 si motor
- How do you adjust coilovers?
- Mazda Wheels on a Civic
- "Skunk2" engine... WTF?
- how many 02 sensor holes are there in 96-00 civic ex coupe catalytic convertors?
- 1995 Civic EX Coupe.. good deal?
- Euro spec Civic...Germany trip
- B16A Fuel Rails troubles..
- comporession test
- Coming to you live from.....
- JDM EK question
- got a new motor
- When do you need alignment?
- Power Window Help Please
- Shocks + struts
- hondabond
- AC Question here too
- anyone deal with www.speedstash.com??????
- AC question.
- CTR Cams
- cruise control question
- threw a rod cause of nitrous.
- Quick Quick i need help- s2k muffler worth 50 bucks?
- please add to online recourse
- Finally got around to it...:)
- 95 CIVIC HANDLING LIKE S%&*T
- Suspension setup
- A light when VTEC kicks in?
- bought new plugs now what?
- gauge cluster install HELP!
- ? about distributor rotor
- Cam Seal
- GSR throttle body
- k20?
- Jdm Jam
- installed my zex kit.
- DMV Problems
- 1998 honda please help!!!
- radiator stop leak products, worth a try?
- Is there a difference in 92-95 5spd trannies
- Upper Tranny Mount
- car alarm suggestions
- ECU question
- Help with 1995 Honda Del-Sol please!
- 91 Plymouth Laser vs Me?
- Happy Birthday CivicSiRacer
- OEM engine mount replacement
- Little helip with overheating '94 ???
- Del Sol Headlight Conversion
- procharger dyno charts?
- A couple of B16 questions....
- Turbo or Supercharger???
- engine swap
