got diagnosed at autozone
Old May 16, 2004 | 07:49 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default got diagnosed at autozone
the cel said something about o2 sensor low reading (i dont exactly remember, something about being low or slow reading/voltage), does that mean my 02 sensor is bad, or something else is causing a low/slow reading
Old May 16, 2004 | 02:20 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
it would help if we had the code to better help you... what P number did they give you? P0135? P0141?
Old May 16, 2004 | 06:50 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
i've had an o2 sensor CEL for almost three years now h:
Old May 16, 2004 | 09:06 PM
taz77's Avatar
taz77
that's not really much of a diagnosis, is it?
if you can get to the o2 sensor and get a voltmeter to it... do it. take a look at the numbers going back to the pcm. get a $2 bottle of propane with a on/off valve and shoot some propane into the intake. see if the voltage on the o2 increases.
if it increases really fast... like in less than a second... your o2 is fine.
if it doesn't change or changes slowly (like .2v going to .8 volts in like 5 seconds), you go a lazy or defective o2.. then replace it.
Old May 16, 2004 | 10:25 PM
Josh M's Avatar
Josh M
It depends, if your O2 sensor was still in closed loop or if it was operating in open loop after it warmed up a little bit.
Old May 17, 2004 | 05:28 AM
westcoaststyle
That is about 10 times harder than the HELMS method.
In the online resources thread at the top of this section there is a download for the 5th and 6th gen civic HELMS manuals. Find out what the P code is and do the troubleshooting methods listed in there. It will require a multimeter with continuity, voltage, and resistance capabilities.
hih
Old May 17, 2004 | 08:55 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
don't really remember, but if i had to choose P0135 looks more familair
Old May 17, 2004 | 09:08 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
sounded more like this "P0133 Heated Oxygen Sensor Circuit Slow Response Bank 1 Sensor 1. "
Old May 17, 2004 | 09:09 AM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
i reset it, have yet to come back on
Old May 17, 2004 | 09:25 AM
westcoaststyle
If it does, use that HELMS manual to troubleshoot it. :goodjob:
