turbo from rx7 ?
turbo from rx7 ?
Ok my friend is baying a new motor whit a new turbo for his rx7, he is ok in give me his t03 turbo and inter cooler
My question is cane I put the turbo to a d16y8 or what do ay need to
Moderator Alumni
Anything is possible. Sounds like it would definitely be a custom job. It will take some planning and maybe a lot of custom fabrication ... ultimately it may take a lot of $$ compared to a turbo kit that is ready to go. Hopefully there is someone on the board that has done a similar turbo project. Good luck.
2005 s2000
2005 s2000
you probably need a custom made manifold and plumbling. also the turbo's made for rotary's differ a little than turbo's made for piston engines. you might want to take that into consideration when it comes to boost and output.
CockBlockerator
step 1- find a/r and trim size to see if this will work well for your car
step 2 - find out the type of flange it uses for the exhaust manifold
step 3 - check for the condition of the turbo by shaft play on the turbine on the compressor side and any signs of oil in the compressor turbines and exhaust side...
if all look good you can try to fabricate it to your car...
Your Powder Coater
either way.. your going to need the same amount of stuff.. T-25 will spool quickin on the y8 tho!
like igo4mbx said check for shaft play with what ever turbo you decide to get & find a manifold that goes along with it. If you need some help on finding best prices on the net lemme know.. I just peiced together my new turbo kit.
found a plage to get 35mm wastegates that would work good on a t-25 for $150 shipped!
Just post u'r questions & status on this project here & u'll have all u'r info in no time!
it's my D in a B
Originally Posted by CHINO-D16
I DONT have a lot of $, so I think I goin whit the saab turbo or t25
