near empty gas = longer crank time
Old Apr 30, 2004 | 10:31 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default near empty gas = longer crank time
gas near empty = 1-2 seconds extra crank time to start
most likely problem, fuel filter or fuel pump?
Old Apr 30, 2004 | 10:36 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
Default hmmmm
i just got to thinking, does this mean, when driving with a full tank, fuel will actually come out faster/more, which means i burn gas faster...
another thought, if i was the reset ecu with a full tank vs empty tank, will that make a difference.
Old Apr 30, 2004 | 10:44 PM
mxl36o's Avatar
mxl36o
1999 Accord 4 cyl
btw on the highway i get 40mpg on highway
Old Apr 30, 2004 | 11:13 PM
Jafro's Avatar
Jafro
I'm made of meat!
You're thinking way too hard about this. My car does the same thing. It's normal.
Your fuel sending unit has to pull gas from the bottom, and push it out the top of the tank. If the level is low, it takes longer to build up the pressure to move the gas.
You'll notice with the fuel level low, and after cranking the car to start it, you can immediately shut it off, wait a minute, and it starts immediately. That's because the pressure is held in the fuel line after you shut the car off, and when you start it the second time, you don't have to wait for the pressure to build up. If you let it sit for a while, the pressure releases back into the tank.
Old May 1, 2004 | 07:48 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
most likely problem, paranoia
just kidding... no, thats normal. Nothing wrong at all, buddy :thumbup:
Old May 1, 2004 | 08:45 AM
Bumnah's Avatar
Bumnah
So OG it hurts.
i notice a lot of people don't wait for it to stop beebing before they crank it over.
turn to on posistion wait about 5 secs and it'll fire up quicker.
Project EVA - The Track Package
Project EVA
Old May 1, 2004 | 10:16 PM
smudge's Avatar
smudge
You do know, that it is hard on the pump to run when low on gas. I fill when it hits 1/4 (i haven't hit 1/8 in 3yrs.).
Old May 2, 2004 | 07:01 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
damn i get all paranoid when i hit less than 1/2 tank! guess its my OCD, i cant go without having less than half tank or ill go nuts.
Old May 2, 2004 | 08:02 AM
Hondaman's Avatar
Hondaman
Black Pearl
I test my low fuel light on a regular basis. Just to make sure it's functioning properly. :rick:
Old May 2, 2004 | 08:28 AM
white_n_slow
it's my D in a B
my car doesn't even have one I've run it out of gas a few times (while delivering pizza) h:
