car wont start
I just put an LS engine with a b16 tranny in my 1998 Honda civic HB I used my stock wiring harness from the DX engine and put it on the LS Engine Now the car wont even start. What could it be????
All the grounds are hooked back up? The battery and the fuse box wires are hooked up back? The starters wired up? Is there any power in the car (you get noises and lights but it won't turn over)? You need to give a lot more info.
First check the main relay. You should hear a clicking noise coming from your fuel pump. if you don't, it's your fuel pump. IF it does work, then check to see if you have any spark. If you don't have any spark then that's your problem, it's in the distributor. if you want you can also jump your main relay. I don't have the wiring diagram for your car but it's pretty easy to jump the wires coming from the main relay. See if it starts from there.
Tr0LL
92+ Civic/EL & Del Sol
14
Mar 6, 2003 09:20 PM
