turbo fuel management Q
Old May 22, 2004 | 10:25 AM
Civic2Scooby's Avatar
Civic2Scooby
Default turbo fuel management Q
ok I am plannin on doin a homemade turbo setup in the up coming few weeks, and was wondering if I can use a VAFC as my fuel management. I am only planning on a minimal boost setting, until I really get to know turbo and how it works and I can really start building the block etc etc.
Old May 22, 2004 | 10:54 AM
pomansouth's Avatar
pomansouth
I would say yes, but it wont give you as great of an amount of flexibility as would a hondata. Go ahead and get it because it is cheap, works up to a certain extent, and get it tuned by someone who knows what they are doing. That said, you can probably run up to ten psi with some experience and building of the motor. Maby more then that but that is a round about guestimate.
Old May 22, 2004 | 11:02 AM
Civic2Scooby
I am only plannin on runnin around 6ish psi for now, and I got a great deal on the VAFC. for 6psi am I gonna need to upgrade injectors or anything like that? I would think they would be fine. I am prob. gonna scoop the missing link as well.
Old May 22, 2004 | 11:06 AM
pomansouth's Avatar
pomansouth
it seems to me that you have your head on straight so far. The injectors will probably be fine, the missing link is an easy way to do it but it can be done for alot cheaper, like 6 bucks, the Vafc is on a good deal right now, grab it up before you get passed up.
Old May 22, 2004 | 11:09 AM
Civic2Scooby
I just spend a good few hours a month ago putting on the p30 mani to eliminate all the extra vac lines and garbage. So I am gonna spend the extra few bucks on the missing link so it doesnt look like a fish tank store under my hood
Old May 22, 2004 | 11:42 AM
supermac88's Avatar
supermac88
not OG but Old School
you don't use a missing link with the AFC Hack the VAFC splices your map signal and you can alter it.
Old May 22, 2004 | 12:01 PM
Jafro's Avatar
Jafro
I'm made of meat!
Just be sure to keep the rest of your fuel system straight. The biggest thing to worry about is getting enough fuel pressure when you're under boost. An AFC can regulate your injector duty cycle, but ensuring that your fuel pressure rises 1 PSI for every one PSI of boost is the most critical. OEM Honda fuel systems really don't flow very well, so I wouldn't trust the stock regulator if this car is going to be daily driven or if you're not running Hondata (so that you can monitor lean conditions).
Old May 22, 2004 | 12:11 PM
ragerized's Avatar
ragerized
dc4 ownerages
what exactly is this missing link?
Old May 22, 2004 | 01:59 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
have you picked a turbo yet? I may have one that'll work for you for pretty cheap. PM me :exnbp:
Damn all you assholes actually making progress with your cars :madglez: hfawk:
Old May 22, 2004 | 02:25 PM
Civic2Scooby
good shit...thanks.
I am planning on doin all the wiring myself, but then it will just sit untouched till I get it to the tuner.
well I mite play with VTEC on the highway so I can get better gas mileage.
