Check Engine Light CEL error 41 help
FIXED PROBLEM Check out the DIY if you have this problem Here!!
I have my CEL on and the code is 41 which is 'Primary Oxygen Sensor - Heater circuit malfunction' Now I've looked around here and some other places, but I haven't really gotten a clear answer. My Haynes manual doesn't herp much either
Has anyone had this problem or know how to fix it?
It's the heater inside the o2 sensor, you can't fix it you have to replace the o2 sensor.
Newer o2 sensor's have internal heaters that warm up the o2 sensor to like 400 f when you start the car to reduce cold start emissions and to get the o2 to start working faster.
Originally Posted by PHiZ
Most likely your o2 sensor went bad.
If you're not comfortable replacing it, I have a friend in Fall River, MA that could hook you up.
-PHiZ
-PHiZ
